Question about Frigidaire FEF336BC Electric Kitchen Range
Could you help on the installation of a frididaire electric range? we are having some problems cant figure out why? 2nd range we bring home and the problem is the same. With the 3 wire connection we can't get the digital display nor some of the lights to come on.
  • 1 more comment
  • smbf01 Jul 25, 2009
    I have a 4-wire cable. And is installed according to instructions. But the digital portion of the range is not functioning, and this is the second (new) range I,ve tried. My old range was analog and also had a 4-wire instalation. All connections are pretty much straight forward, but obviously I,m doing something wrong
  • seawizz72
    seawizz72 May 11, 2010
    Are the three wires you are speaking of the 220volt power connection? This would be the pigtail to the outlet and how it is wired to the range. Which three wires are you speaking of?
  • Da Builder May 11, 2010
    Are you sure both hots & the ground are good and making connection in range receptacle? 2 stoves same problem sounds like problem. Could be one cartridge fuse if old wiring. Or loose wire if breaker box.
  • 24 Answers
Is your 4th wire a 110 line or utility ground. if it is 110line it is problem. Use cicuit tester to be sure working.
Posted on Jul 25, 2009
    Problem Solver:
  • 9 Answers
could you help on the installation of a frididaire - 8ce06d2.jpgThese are the configurations for four wire connectors. You need to identify which one you have, then check the voltage according to the diagram. More than likley, you will need to rewire with proper wire from fuse/breaker box. If one voltage is missing it could be a blown fuse on one pole but it sounds like it was never wired for four wire. Photo couortesy of Ugly's
  • 520 Answers
This is because you will need a 4wire circuit which includes a common wire (white) for the 110v items to operate such as lights or panels.
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
Sep 05, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
On my Frididaire Glef396csb, when operating the oven, the light flickers on and off and the power to the oven also goes on and off.
Good Morning Cecil,
I see that you are having trouble with the light flickering on and off and also the power going on and off on your Frigidaire range, model# GLEF396CSB. You also stated that there is a clicking noise, as if the door switch is not connecting. There could be a couple of possibilities with these occurences.
First, make sure that you are connected to a 120 volt at a minimum of 40-50 Amp circuit breaker.
Second, there could be something going on with the different control boards miscommunicating.
Third, there could be something going on with the wiring inside the home.
In any case, I would start with resetting your range. You can do this by shutting the power off at the circuit breaker for 2-3 minutes. When you restore the power, you will need to set the clock by pressing the "clock" button, entering in the time, then pressing the "Start" button. Once the clock is set, turn on the oven. If you are still having trouble from there, I would contact either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
Mar 19, 2014 | Frigidaire GLEF396 Electric Kitchen Range
HOW DO I TAKE BOOTOM BURNER OUT FRIDIDAIRE GALLERY CFES 388REB1
Hello rdbal - Most bake and broiler elements are typically held into place with 4-6 screws or fit(s) in a bracket like connection and then needs to be screwed down. However every unit is different so please contact a professional to move accurately for more information due to safety and liability reasons.
Nov 11, 2012 | Frigidaire Gallery GLEFM397DS Electric...
How to install the pwer in my range
black on the left
red on the right
white in the middle
Oct 07, 2009 | Hotpoint RB757 Electric Kitchen Range
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frididaire electric Range
you cant fix it but if there is a local used appliance store they may have a used clock. Call around and check. But the clock is deffinately your problem.
Nov 10, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Frididaire oven
Could be a problem in the thermocouple and the oven overheating. Get a good oven thermostat and check to see what the internal temp really is. You rack isn't too low is it? MM85
Jul 27, 2008 | Frigidaire FES367 Electric Kitchen Range
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
153 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
