Question about Refrigerators
I ave a Norcold refrigerator in my vr. A fault code appear "Li" "LO" What can i do?
We have a 1999 Hurricane Motorhome. What would cause a big bulge inside our Norcold refrigerator. It appears something must have been hot to make a big bubble inside the fridge. Thank you. Sharon
Contact the Norcold factory.
That may take you a while.
I suspect the fridge is an automatic defrost.
If so, they have heating coils inside the walls.
If one stuck on, that could cause that.
Type Norcold into your computer search engine.
God bless your efforts.
Jul 03, 2017 | Refrigerators
What is issue with my Norcold N3150 not cooling on AC with fault code8?
The "new" refrigerator could have been damaged/defective when you bought it. After all, that door got dented somehow. This should be resolved among you, the seller, and eBay.
Jul 06, 2016 | Refrigerators
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
Free download norcold n611 rv refrigerator manual
DOWNLOADS
Parts List-06-08-12Reference6/13/2012669.77 Owner's Instructions - Cooling Unit InstructionsTechnical7/12/200728.17 Installation Manual - 3/23/06 - 2/19/07User Manual7/12/2007872.04 Installation Manual - 8/2/04 - 3/23/06User Manual7/12/2007791.81 Installation Manual - CurrentUser Manual6/16/20091,239.84 Installation Manual - Through 8/2/04User Manual7/12/2007508.79 Owner's Manual - 3/23/06 - 2/19/07User Manual7/12/2007370.63 Owner's Manual - CurrentUser Manual1/20/2010630.82 Owner's Manual - Through 3/23/06User Manual7/12/2007394.09
I believe you can find the fault codes above. Here is a link to the Norcold N611 Information and Contact Page
Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
Fault code on norcold refer model 640.3 reads "no" "co",how do I reset
u must take into a dealer or have a mobile tech to reset the board
Jul 29, 2009 | Thetford Norcold RV Cooler/Freezer
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
