Question about Electric Garden
I have a electric task force weed eater and am having problems restringing it. Ive taken the top off and placed it in the holes but when I put it on the ground the string pops out.What am I doing wrng
  • 718 Answers
SOURCE: need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Posted on Jun 01, 2009
SOURCE: I can not put the string on my weed eater
Remove the bolt holding the spool in place. Unscrew the cap and turn the spool. that should give you access to the spindle that holds the line. Put the new line in the starter hole and reverse the process. You should be ready to go now
Posted on Jun 16, 2009
  • 65 Answers
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Posted on Aug 22, 2009
  • 279 Answers
SOURCE: Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Posted on Sep 06, 2009
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
Why does the string keep breaking on a task force electric weed eater
Hello, When the string gets old it dries out and becomes brittle. I soak my trimmer string in water until I am ready to use it. The string actually absorbs some water and stays flexible. Try it.
Aug 28, 2014 | Garden
How do I load the string?
Hi j_janes....
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker String Trimmer Cordless 12"...
Need to replace the wirefeed? Purchased 8" orange
Hi gramcherry1...
Jul 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
Line installation
Hi bluemontel52...
Hi
Jul 03, 2011 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How to replace string on te475y
Hi jtl91370...
Try this solution...
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
I like to know how to wier the line om my poulantrimmer model ppo25\
Hi rlgingas...
Some you will have to remove the center knob.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How do we add line to the trimmer?
Hi jeff clar0
Jul 01, 2011 | Husqvarna 28cc Gas Line Trimmer
Need to add new string to a weed eater xt 12
    For manual go to;
Jun 01, 2009 | Garden
Garden Logo
26 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
