Question about Light Garden
I have a Mahindra 4110 the PTO light comes on but does not engage..
Rayvin1943
  • 97 Answers
SOURCE: Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Posted on Jul 19, 2009
bbreton
  • 437 Answers
SOURCE: When engage the PTO switch, nothing happens.
Not knowing what mower you have from the information you have given; There are several possibilites; The ptop switch could be bad, the pto on the engine that engages the blades may be burned up or you can have a fuse or safety relay needs replacing. If you know your model number, you can go to www.precisionope.com and look at the diagrams and parts you will need.
Good Day.
Posted on Oct 21, 2009
Testimonial: "Thanks much!"
wireguy212
  • 1627 Answers
SOURCE: When I engage the PTO clutch, the amp light comes
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Posted on Nov 07, 2009
  • 146 Answers
SOURCE: Cub Cadet 1861 amp light comes on when the PTO is
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Posted on Jul 09, 2010
  • 6468 Answers
SOURCE: pto would not engage engine running
check the belt
Posted on Apr 03, 2012
The pto grinds, and will not stay engaged on my Mahindra 475 DI. Is there a simple fix?
No you will need to pull it apart and see what is broken.
Jul 05, 2017 | Garden
Mahindra 2538 will not run more than 2400RPM with no load. tried to increase the rpm after engaging the pto, it blew white smoke and stuttered and would not rev up. ,it has less than 40m hours on it
White smoke usually indicates you are trying to burn water/antifreeze... STOP.. take it to your local dealer for diagnosis... either a head gasket or maybe intake gasket,, worse case is cracked head..
Jun 19, 2017 | Garden
2810 Mahindra tractor electric PTO does not work also engine does not shut off when key is turned off also fuel gauge stays on full. can this all be from the same problem?
most probably a faulty relay in the ignition circuit for the gauge and running on problems
probably a relay for the pto not being energized from the pto switch
Oct 23, 2016 | Garden
Everything works fine until I engage the PTO for the mower deck. The battery discharge light comes on and eventually the battery goes dead.
The PTO clutch is an electro magnet. There is probably a dead short within the clutch body. Replace the Clutch.
Aug 26, 2015 | Cub Cadet Garden
As soon as ignition key is turned to run PTO engages
check your pto switch with a test light turn pto switch to off take T/ light ground it good turn ignition on and if light comes on you have a bad pto switch
Mar 17, 2014 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
100 people viewed this question
Top Light Garden Experts
Richard Schanie ...
Arnie Burke
Arnie Burke
Ted Maxwell
Are you a Light Garden Expert? Answer questions, earn points and help others
