Question about Garden
Whats the diffence between a star whole and a round hole on a lawn mower blade
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
It may be the way the blade was made to attach to the spindle. You will have to clean away debris with a wire brush when you remove the blade to see for sure.
Posted on May 02, 2017
Whats the diffence between a star whole and a round whole on a lawn mower blade
If your mower uses a star hole on the blade,then you must replace blade with a star hole,you can raise the mower up and see the star that the blade attaches to.
May 01, 2017 | Garden
Remove mower spindle star is stripped blade moves
If star is actually stripped, you will have to replace the whole spindle assembly and blade. I would not change just the shaft if I was you as its almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade will not tighten star stripped on spindle
You will have to change the spindle and blade. I would replace the whole spindle assembly as just the shaft is almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
How do i change blade
Under the mower,the blade is held by a single nut.Unplug the spark plug.Lift the mower.You will need to hold the blade.I use a large screw driver to keep the blade from turning as you remove the nut.Do NOT but a blade before you get the old one off.Some blades use a star shaped hole others use a round one.You need to know which you need,as one will not fit on the other.Once the nut is off the blade will come off too.Then just put the new blade on and the nut.
Jun 29, 2011 | Garden
Taking off the mower blades on a husqvarna z4824
Sometimes the blade bolts are tight from the factory.Try and lift the front of the mower to get under the deck if you don't want to take the deck off. If you don't have an impact gun use a small piece of 2x4to wedge between the blade and the edge of the mower housing to stop the blade from turning while you use a 5/8 socket on a 1/2 inch breaker bar or large ratchet, be careful you don't slip and cut yourself on the blades,wear gloves and when reinstalling blades be sure to align the star hole in blade with the star on the blade mandrel
Jul 09, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Saxon lawn star 15.5 hp. Blades wont engage
Hi you may need to adjust the clutch the recomended clearence is 10 thou you use a feeler guage in the holes on all three sides and adjust the 3 nuts in
Jun 29, 2009 | Cub Cadet Street Sign- tractor lawn riding...
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
