Question about Garden
Whats the diffence between a star whole and a round whole on a lawn mower blade
  • Garden Master
  • 14,398 Answers
If your mower uses a star hole on the blade,then you must replace blade with a star hole,you can raise the mower up and see the star that the blade attaches to.
Posted on May 02, 2017
Whats the diffence between a star whole and a round hole on a lawn mower blade
It may be the way the blade was made to attach to the spindle. You will have to clean away debris with a wire brush when you remove the blade to see for sure.
May 01, 2017 | Garden
Remove mower spindle star is stripped blade moves
If star is actually stripped, you will have to replace the whole spindle assembly and blade. I would not change just the shaft if I was you as its almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade will not tighten star stripped on spindle
You will have to change the spindle and blade. I would replace the whole spindle assembly as just the shaft is almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
The spindle with star shaped end that attaches
the reason it sheard off is because you did not put the blade on right.
you have to hold blade in position untill you turn nut all the way up and make sure blade has the star part in the blade when you tighten it.
you have to buy a new shaft most come with the lower bearing on them.
Jun 21, 2010 | Husqvarna Garden
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Taking off the mower blades on a husqvarna z4824
Sometimes the blade bolts are tight from the factory.Try and lift the front of the mower to get under the deck if you don't want to take the deck off. If you don't have an impact gun use a small piece of 2x4to wedge between the blade and the edge of the mower housing to stop the blade from turning while you use a 5/8 socket on a 1/2 inch breaker bar or large ratchet, be careful you don't slip and cut yourself on the blades,wear gloves and when reinstalling blades be sure to align the star hole in blade with the star on the blade mandrel
Jul 09, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
The star mounts on my poulan 42'' riding lawn mower
Without knowing your mower for sure, I think I know what you may need to do. Most often, you just need to remove the block that the pattern is on. These are most often bolted onto the shaft. If you don't have your parts book for your mower, you may bee able to look it up online.
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
