Question about LG Washing Machines
Where is the drain filter on lg 4408dle - LG Washing Machines
  • LG Master
  • 2,374 Answers
Lg Washers have model numbers that start with WM
LG dryers start with either DLE(electric) or DLG(gas)
so check your model number and add comment below
Posted on May 02, 2017
Lg wm-3470hva
Sounds like the drain pump itself is defective
Nov 07, 2017 | LG Washing Machines
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
May 26, 2011 | LG WD-3245 Front Load Washer / Dryer
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
My LG Tromm WM1814CW is not draining. I cleaned out the drain filter and checked to make sure the drain hose is not kinked and still - there is no water draining from the machine except when I pull out the...
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Jan 26, 2010 | LG WM1814CW Front Load Washer
ERROR NOT DRAINING
the filter is located right after you open the drain cover on the bottom of the washer it's a hard plastic filter, if it is not clogged with any debris, then it sounds like your pump motor is bad, maybe need to replace it. lg's are very sensitive........., find out the part number and search it through google. if not email me and i could set sumthin up for you.
drsn777@hotmail.com
dave
Dec 08, 2008 | LG WM2688HWM TROMM SteamWasher
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
Oct 28, 2008 | LG WM2277H Front Load Washer
0E error
Product Laundry Washer
Symptom Error Codes
Sub Symptom OE error
Question Drain Problem Error.
Answer
Make sure that drain hose and drain filter are not bent or clogged. In case of there are objects in the drain filter, It might drain to slow or not at all. HOW TO CLEAN THE DRAIN FILTER 1. Allow the washer to cool down before cleaning the drain pump filter. 2. Open the lower cover cap with a tool such as coin. 3. At this time use a catch pan to prevent water from flowing onto the floor. Unplug the drain plug, allowing the water to flow out. When water does not flow any more, turn the pump filter open to the left. 4. Remove any foreign objects from the pump filter. After cleaning, turn the pump filter clockwise and insert the drain plug to the original place. Close the lower cover cap. If the drain filter is not clogged, you will need to call LG Customer Service at 800-243-0000.
Aug 18, 2008 | LG Washing Machines
Washing Machines Logo
60 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
