I pushed the wps button and 15 min. later it goes offline. this has happened 5 times in the last 2 days that i have owned it
SOURCE: Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Posted on Aug 21, 2007
agitateme
  • 88 Answers
SOURCE: kenmore electric dryer model # 87670100
The motor is weak and needs replaced, don't hold the start button too long or you may smoke the motor's thermal protection and it could get smokey and stinky. Make sure you can get the blower wheel off before you make a run for parts, sometimes you have to break them off the shaft. : (
Posted on Sep 17, 2008
GasPipe
  • 16 Answers
SOURCE: fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Posted on Feb 23, 2009
romsky79
  • 822 Answers
SOURCE: I have a RCA L32HD32D, will be on for 1 to 5 min. later goes off
check secondary power supply. check capacitors and apply fresh solder.
Posted on Jun 01, 2009
  • 94 Answers
SOURCE: trying to connect wireless, but computer does not
you try to uninstall the driver and restart the pc against , then try to install the proper software again. it work properly
Posted on Jun 29, 2009
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
where is the WPS button? - Canon Community
community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Nov 19, 2015 | Computers & Internet
Tip
HELLO TUNE TRICK FOR AIRTEL( legal)
<b>hi Guys...<br />im 1st tym posting mah Trick Which im using from Last 2 months...<br />THIS TRICK HELPFUL FOR THOSE WHO MAINTAIN LOW BALANCE ON PHONE (LESS THAN 10/-)<br /><br />WITH THE HELP OF THIS TRICK U CAN USE HELLO TUNE FOR 10 DAYS @RS 5 ONLY...<br /><br />Now trick is here...<br />.<br />Keep balance app. To zero.. keep balance rs 1 or less than 2...<br />Now call 578785 (toll free) and acticate ur Favorite Hello Tune...<br />after activating.. Ur balance goes to minus 5 (-5)..<br />Dats it...<br />UR HELLO TUNE WILL BE ACTIVATE FOR 10 DAYS... (15 + 10 for just 5 rs.)<br />NOW RECHARGE.. Airtel wont charge u anything later...<br />..<br />.<br />now when ur 10 days are going to over Reduce ur Balance to 1 or less Than 2..<br />Keep ur balance low untill Ur Hello Tune subrcription renew..<br />After 10 days airtel again do ur balance to -5 and renew ur hello tune for 10 days...<br /><br /><img src="smile.gif" /><br />Thats the 100% legal trick.. Working 100% in delhi...<br />Im using it for last 2 months...<br />Enjoy...<br />And reply if its working in ur state or not.??<br />Hit thanx for my work...</b>
on Jan 29, 2011 | Cell Phones
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
Jan 06, 2015 | Computers & Internet
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
Water was splashed on cell phone, didn't notice for 15 mins. dried off phone and later that day phone kept turning off and on. took battery out and let dry for 2 weeks. it turns on but the lower two...
no sorry- it is replacement time.but itis covered under the insurance if you have it under water damage as long as it stopped working in the last month.
Aug 18, 2009 | Motorola Mobility RAZR V3
Wont start 1995 bmw 525. just stopped on me pushed out of road day later it started and ran fine for 15 min. now it wont start unless it sits for a few days and is cool outside. when it starts last few...
next time it wont start, spray some starter fluid into the air intake on the engine, if it fires then you have spark, if not.....prolly a spark issue.
Jul 13, 2009 | BMW 525 Cars & Trucks
My panasonic viera plasma tv is shutting off on its own
U WILL LAUGH, WHERE THE PLUG GOES INTO THE ACTUAL TV, NOT THE WALL, PUSH IT IN BETTER...I HAD EXACT PROBLEM AND CAME FROM 2 1/2 DAYS FROM GETTING NEW PLASMA!!! WHEEEW
Jan 27, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
1993 ford crown victoria lx new battery, car stopped, won't turn on???
Sounds like you have a bad heater core. If steam is on the interior you may want to look for moisture around the floor at the firewall.
Aug 03, 2008 | 1993 Ford Crown Victoria
My samstron monitor goes dead after 5 min
The problem is not yet serious, no parts yet to replace. That is a result of a "cold solder" of the parts inside. Open the case, clean it with a soft brush and look for these cold solders on the circuit board... resolder what you find and check every pin...
see picture, the rings are somewhat the start of disconnected pin from being soldered.
After that test the monitor..... That's it... Fixya me okay...
Rate us Best for your own future reputations.
Feb 10, 2008 | SAMTRON 55V 15" CRT Monitor
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
