Question about Air Tools & Compressors
I need paint cups for a HV lp gf spray gun I - Air Tools & Compressors
SOURCE: problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Posted on Nov 20, 2008
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Posted on Apr 02, 2010
  • 4088 Answers
SOURCE: i need a kobalt hvlp spray gun manual where can i get one?
Go back to where you bought it and have them photocopy the book from another unit. Good luck!
Posted on Jun 21, 2010
  • 15 Answers
SOURCE: i have a 33 gpm half hp spray gun it keeps losing
diaphram is weak replace it!
Posted on Feb 25, 2011
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
I am using DeVILBISS JGA_510 cinventional spray gun. The pressure pot system is showing constant pressure , but the gun is sputtering and not getting an even paint flow. I have changed paint lines, put on...
First start with the basics, whats the paint VISCOCITY ON A FORD 4 CUP ??
Or Does it run nicely off the stick you stirred it with??
If its thin enough to go up the tube and lines, whats the fluid tip and air cap combo your using?? maybe start with a EX fluid tip (1.8mm) and 30b air cap (cos that sprays everything!!) and reduce from there.
Whats the pot pressure?? Is it a KBII pot? cos they suffered with the air inlet blocking, so IT SHOWS GOOD PRESSURE, but doesnt have it in the pot!
Does it spray anything?? thinners?
Mar 07, 2011 | Air Tools & Compressors
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
I have just purchase a Wagner W550 electrical spray gun. Not having used one before I need to know how do I know if the coating mayterial need to be diluted and if so by adding how much solvent. I intend...
Have a look at the instruction manual. It should state the viscosity that the paint should have. Use a viscosity cup to measure the time the paint takes to drain from the viscosity cup. Dilute the paint if it takes too long.
Nov 24, 2009 | Wagner Air Tools & Compressors
Blowing paint out trough cup
It is clogged and needs to be disassembled and cleaned with MEK. methyl ethel ketone
Aug 01, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
101 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
