Green screen and blinks off and screen turns blank and have had TV for 4 years
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on May 02, 2017
  • 113 Answers
SOURCE: 60" Sony KDF-E60A20 - Red Light Blinks 6 times
The problem you have is a failed thermal sensor. Depending on how tech savvy you are you can replace it.They have changed the way the thermal sensor looks but it isnt too bad too put in. Any repair shop should also be able to do this for you.
Part number is 1-910-006-44 Themal Fuse Sony Part.
Posted on Feb 04, 2008
SOURCE: green light blinking screen blank
It is not a computer issue. It is a power issue with the monitor. A tiny capaciator needs to replaced which requires soldering.... better just buy a new monitor if not under warranty
Posted on Mar 17, 2008
SOURCE: Sony KDF-46E2000 - Screen Goes Blank
Ok, the solution for all our problems is in fact the lamp. I finally replaced my lamp and no problems to report. Sony should do something about this because I know I didn't have 8,000 hours on the lamp and it sounds like no one else has either. I tell you what, I'm NEVER buying another Sony product ever again. Not only did I have this problem but I bought a Sony Blu-Ray disc dvd player and I've had nothing but problems out of it. I keep getting firmware updates for it but it doesn't help and recently I bought a Sony Walkman MP3 player and for no reason it quit working, it would power up and immediately power off. Sony did replace it though (but of course it was only $70 compared to the prices of the tv and dvd player).
Anyway, if you are still having problems with your tv, the lamp door is on the right side, pop it open and there will be another door with a knob on it. Turn that knob counter clockwise to unlock it and pull it out. Inside that door you will see the handle for the lamp, put your finger through the loop and pull up and out at the same time, to put in the new lamp, push lamp straight in until it won't go in any further and puch down, it should then be locked in place. Replace both inner door and outer door and you are good to go.
Someone mentioned something about cleaning the dust from around the lamp. I tried that before I got my new lamp. It only worked for a day and gave out again. Hope this helps.
Posted on Aug 14, 2008
J Kitch
  • 84 Answers
SOURCE: blackberry pearl 8100 blank screen & green blinking light
Try performing a hard reset: remove the battery from the device while it is still powered on, leave it out for 30 seconds, then reinsert.
Posted on Oct 05, 2008
mistersony
  • 320 Answers
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Posted on Nov 09, 2008
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Feb 12, 2011 | LG 42LC7D-UB Television
My Hitachi P50x01au plasma TV screen goes blank suddently, and the power indicator green light blinking. TV cannot be turn off by the remote. I switched off the power manually, and turn it on, but the...
I would open back and check all boards for cracks, this is a problem with these sets.Then count the blinks on the set and see if it stops for a moment and starts back.
Jan 19, 2011 | Hitachi Televison & Video
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony kp-53xbr35 Rear Projection TV screen turns green for a few seconds when I turn it on, then goes blank. Audio still works. Timer/Stand-by blinks until screen goes green, then stops, even when screen...
check the lamp out if the lamp go to this website http://www.discount-merchant.com or if the lamp is not the issue maybe can be the board in the same page you can find the parts that you maybe would nedd
regards
Dec 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Blinking Green Light on Mitsubishi DLP 52525
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
Televison & Video Logo
Top Televison & Video Experts
