Question about Vizio Televison & Video
I have taken 32 screws off the back of my VF552XVT vizio tv and still can not get the back off. The top is loose but the bottom is still tight. I don't see any more screws.
    Top Expert:
  • Vizio Master
  • 75,157 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations
Posted on May 02, 2017
I have a ge universal remote. How do you program to a vizio smart tv Model # vf552xvt
Use code search to find something that handles some or all TV functions. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
May 23, 2017 | Vizio Televison & Video
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
I have a 55' Vizio Tru LED model VF552XVT. The TV ran fine for a year and a half and just recently the screen started shutting off after a few hours. I am aware that there is an issue where Vizio
It sounds like an overheating issue with the T-con board. You shouldn't have to run a house fan behind the TV to keep the screen on. Make sure you have the TV in a place where there is enough space around it to allow for air flow. Also, check to make sure the ventilation slots on the back of the TV are not blocked with dust.
Aug 30, 2012 | Vizio VF552XVT 55" inch Class XVT Series...
How do i fix a picture problem on a Vizio VF552XVT?
not a do it yourself repair--one or more boards are possible.
Jun 26, 2012 | Vizio VF552XVT 55 in. LCD HDTV
Wireless won't connect
have you tried resetting the router un plug the ethernet cord and push the little button in using a pin for about 15 seconds then plug the ethernet back up and wait until all the lights are back on then cut the tv back on and see if it connects.
Feb 20, 2012 | Vizio VF552XVT 55 in. LCD HDTV
I have a vizio vf552xvt lcd led hdtv and i wood like some help with connecting my computer dell xps 8100
You can connect your computer in your television by using VGA connector cable or HDMI cable.Then set the TV into PC in by selecting at the menu setting.
Jul 04, 2011 | Vizio VF550M 55 in. LCD HDTV
I think I need a new power module for my Vizio vp322 hdtv10a tv. How do I open the TV to expose this module? There are about 10 million screws on the back of the set.
Remove the 4 screws holding the stand. Remove all the perimeter screws. Remove all the screws from the bottom speaker panel and the rest of the perimeter screws and the ground wire screws at each speaker. remove the screws on the surface of the back panel and you are in. The power supply is the large board in the middle. The bad capacitors are in the secondary and were C233, C234, and C236. I replaced these 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Dec 18, 2009 | Vizio VP322 32 in. Plasma TV
Vizio Problems
I will tell you that there are many screws involved in getting to the boards. Suggestion I will tell you about
Keep the screws separate. Take the legs off first, then the back panel. this will expose the boards. The board on the top is the power board, below that is the main board. on the 32" vizio there is one plug that is located "left off center" that is very easy to break when removing from the board. Just beecarefully
Nov 05, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
