Question about Grohe Home
Hi, I am building a new house, and am installing Grohe products: Need advice on shower and kitchen accessories.
(1) Master suite shower: I have in mind: 27939001 (ceiling shower) 27749000 (Hand shower set) 27251000 (side showers) X 3 Will this work with 19448000 + 29033000 (five way diverter)? (for head, hand, head/side combo, hand/side combo, head/hand/side combo) Can any Grohe five way diverter work with this combination (even though the settings icons are not correct? Kitchen I was thinking of using 32 950 000 32 950 DC0 Professional sink mixer I need s smaller side tap for filtered water system (I am using an Aquaport filtration system), any suggestions? Thanks Dan Ta
SOURCE: Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Posted on Nov 29, 2008
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 14 Answers
SOURCE: Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
Posted on Dec 29, 2008
  • 8 Answers
SOURCE: Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Posted on Jan 08, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
How do I install a growe stem 47175000
WEB:
GROHE - Installation Videos - Services for you
www.grohe.com/us/21532/services-for-you/installation-videos/ Installation and Product Videos. Our faucet videos give you advice for mounting our products, answer technical questions as well as explain our unique ..
Jul 22, 2015 | Home
Growe shower valve install cartridge 47175000 manual?
Jul 22, 2015 | Office Equipment & Supplies
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Grohe kitchen faucet burst supply line
With my past experiance with any Grohe product,you will experiance a problem.I have been doing plumbing service work for 20 yrs. and every time I encounter this product,there is always a major problem.I don't know what the big deal is about this product,it cost too much and parts are hard to come by,you must order most of the time.then wait 3 to 4 weeks.hope it's the right part!
Jun 19, 2009 | Plumbing
I have a Grohe shower head that leaks buckets (not an exaggeration). We bought the parts that we were advised to buy from Grohe, but even the professional plumber couldn't stop the leak or install the new...
sounds like you need volume controls lots of grohe fittings are strictly mixing valves not shut offs if this valve use to work then you need to find plumber familiar with grohe
Feb 21, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Home Logo
24 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
