Question about Coffee Makers & Espresso Machines
Does thge mr coffee brew basket has a spring on the bottom?
    Sergeant:
  • 319 Answers
Yes it does. The spring is around a plastic plunger that closes the opening to the brew basket when you remove the glass carafe during brewing. When you put the carafe back in it pushes up on the plunger the spring is around and lets coffee flow again.
Posted on May 02, 2017
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
ThaMp3Doctor
  • 8596 Answers
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Posted on Feb 06, 2009
SOURCE: Coffee not brewing
This machine depends on heat to move the water to the top. The heating element, or thermal fuse, or burned contacts are the usual suspects. The warmer under the coffee pot is not part of the coffee making process. It is repairable.
Posted on May 05, 2009
  • 199 Answers
SOURCE: My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Posted on Jun 23, 2009
SOURCE: Need parts diagram of Mr. Coffee CG12 filter basket assembly
I found the missing vinyl washer.
Posted on Oct 03, 2009
Mr Coffee istx85. .coffee brews in basket but wont release into carafe ??
Check that you have the carafe positioned correctly ..If the pivot rocker spring is jammed it will cause this to happen..
Oct 14, 2014 | Coffee Makers & Espresso Machines
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
The basket bottom spring-came aprt
it's broke. you didn't say what kind it is, but it's probably cheaper to by a coffee pot
Aug 06, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart Brew Central 12-cup Coffee Maker Filter Basket Anti-dripo has come unattached. We have a spring and the anti-drip puiece. How do they go together?
Hello tfsmithcambr,
You need 3 pieces. The bottom plug, the spring, and the collar. Slip the spring over the plug. Insert the plug into the basket end. Slip the collar onto the inside the basket end of the plug shaft until it clicks. Should be good to go. If this does not work or you are missing a piece, you may need a new basket. Hope this is helpful. Good luck and kind regards, NormanZ
Jul 07, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee pot just would not brew this morning, though it worked fine yesterday morning. I emptied it and started over 3 times. The lights come on but that is all that comes on.
Check the water level. Check to make sure that the coffee filter under basket is clean and not plugged. YOu can remove your filter, then take out the basket and clean it....when did you purchase the machine?
Aug 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
How to
Fill the pitcher with water to the water level park on the pitcher and pour into water intake in the top of the tea brewer.
Fill pitcher to ice level mark (if there isn't one, put in about 2 - 3 trays).
Make sure that the brew basket lever is closed by pushing in then down.
Put 6 - 10 regular tea bags in brew basket and place brew basket on top of pitcher.
Slide the pitcher with the brew basket under the machine where the water comes out and make sure it is snug. Turn machine on.
When the machine is done brewing, the unit will shut off automatically.
Carefully slide the pitcher away from the machine and release the lever. This will let the tea pour into the pitcher.
That's it! Just don't put the pitcher, lid or brew basket in the dishwasher - that's how I ruined my first one.
Jan 24, 2008 | Mr. Coffee Iced Tea Maker TM1S
Coffee Makers & Espresso Machines Logo
128 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
