Question about LG Washing Machines
What does OE mean on LG washing machine. It is DLE4408
  • LG Master
  • 2,159 Answers
Output error. Usually either a plugged pump filter or bad pump motor.
Posted on May 02, 2017
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
I have a code that sa OE and dont know what it means
Check out this tip it will help explain that OE code
LG Washing Machine OE Error Code
heatman101
Sep 26, 2010 | LG Washing Machines
READING A CODE OF OE WAT DOES THIS MEAN?
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine has an OE error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | LG WM2487H Front Load Washer
My lg front load washing machine is reading oe
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
May 20, 2010 | Washing Machines
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
My washing machine
Clean the drain filter out. Then while the filter is out, take a flashlight and look into the filter hole. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Nov 14, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
