Question about Hardware & Accessories
I wish to set the redio news at 7am & 7pm & also set the alarm at the said time
5 Suggested Answers
  • 27 Answers
SOURCE: can't figure out how to set an alarm for 7am
Follow these steps:
Menu>>Alarm Clock>>Menu button>>Add Alarm>>Enable "Alarm" Checkbox, Set time on the time submenu, choose days on repeat sub menu.
Its a little unintuitive but this will work.
Posted on Jun 07, 2010
SOURCE: How do I set my
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
SOURCE: I'm just looking for an instruction manual for
There are several versions of same timer:
Open following link to identify timer and possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Posted on Jun 18, 2011
SOURCE: Need help setting timer to turn lights on at 7pm
Timer is not identified.
Add a comment with clear description of timer for possible instruction manual.
Posted on Sep 26, 2011
How do I call EZ pass? I NEED TO SPRAK TO A PERSON
You did not state which state's EZ Pass you need to contact. Each one has a different set of contact information. The general number is: 1-800-333-8655 Monday-Friday from 7am-7pm.
Mar 23, 2017 | Cars & Trucks
Need help setting timer to turn lights on at 7pm and lights off at 7am
Sep 26, 2011 | Hardware & Accessories
We have no hot water and error code c211
call here for your answer
1-866-720-2076
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
HI, got a problem to start intermatic hb88rc , wont strat after programing
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Let's do a checklist:
> The battery has to be installed before you program timer, so that is good.
> Press Mode button and it over-rides current program ... so mode button acts as the manual override. Try manual override and see if Load comes on.
> The manual override is the real test. Plug something else into timer and use the manual override to see if timer is able to complete a circuit.
> If manual override works then your programming is suspect. (see more below)
> If manual override does not work then electric circuit is off, or timer is bad.
> After using manual override, press clock to return to current time
> Make sure Mode is not set to random
> The clock must be keeping correct time, or you would have mentioned it
> Check that the electrical plug has power.
> Check that the Load (light, fan) operates fine without the timer.
Programming problems:
> The timer program calls for ON time and OFF time for each program. If the ON time was skipped, then timer will not turn ON.
> If there is a conflict in programming, the timer will not operate as expected. For example program1 says ON at 7 and OFF at 8, but program2 says the opposite.
> Another example is when the AMs and PMs are mixed. For example you want ON at 7am TU and OFF at 7PM TU. But the timer was set for ON at 7am and Off at 7am.
> When programming, write out a schedule so there are no conflicts.
> The ON and OFF functions should follow the same days. For example ON is set for 7am TU but Off is set for ALL week.
Nov 09, 2010 | Intermatic HB88RC - 7-Day Programmable...
Can't figure out how to set an alarm for 7am sunday morning
Follow these steps:
Jun 06, 2010 | Motorola Mobility Backflip Smartphone
Blu-Ray disc player model: BD-HP21H
You will need a 2GB usb device a.k.a. a flash drive. You will need access to the sharp web site. You can call 800-237-4277 any time between 9AM-7PM CST today or 7AM-7PM tomorrow to be walked through the software update you need from start to finish.
May 31, 2010 | Sharp AQUOS Blu-ray Disc Player
Drive gear
You can call Sears Parts Direct @ (800) 252-1698
Monday - Friday 7am - 9pm Central time
Saturday - Sunday 9am - 7pm Central time
They will have the owners manual you need. Enjoy your tiller.
Apr 02, 2009 | Craftsman Rear Mount Tiller
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
