Question about Hardware & Accessories
I wish to set the redio news at 7am & 7pm - Hardware & Accessories
4 Suggested Answers
SOURCE: How do I set my
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
SOURCE: I'm just looking for an instruction manual for
There are several versions of same timer:
Open following link to identify timer and possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Posted on Jun 18, 2011
SOURCE: Need help setting timer to turn lights on at 7pm
Timer is not identified.
Add a comment with clear description of timer for possible instruction manual.
Posted on Sep 26, 2011
Where can I acquire 6500W voltage regulator for a Rural King generator
Contact the manufacturer for replacement parts or possible warranty replacement.
1-800-561-1752
7AM - 7PM CST 7 Days a Week
May 05, 2017 | Electrical Supplies
How do I call EZ pass? I NEED TO SPRAK TO A PERSON
You did not state which state's EZ Pass you need to contact. Each one has a different set of contact information. The general number is: 1-800-333-8655 Monday-Friday from 7am-7pm.
Mar 23, 2017 | Cars & Trucks
Flashing number 2 code
Remove batteries.
Insert a paperclip or similar object into the "reset" hole and hold in for 10+ seconds.
Insert new batteries.
This should reset the thermostat to factory settings and clear all programs, and it should work normally afterwards.
If the error occurs again within a month, then call Hunter tech support at 888-830-1326 between 7am - 7pm US Central timezone.
Oct 13, 2013 | Hunter Fan Company 5/1/1 Programmable...
Need help setting timer to turn lights on at 7pm and lights off at 7am
Sep 26, 2011 | Hardware & Accessories
We have no hot water and error code c211
call here for your answer
1-866-720-2076
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Blu-Ray disc player model: BD-HP21H
You will need a 2GB usb device a.k.a. a flash drive. You will need access to the sharp web site. You can call 800-237-4277 any time between 9AM-7PM CST today or 7AM-7PM tomorrow to be walked through the software update you need from start to finish.
May 31, 2010 | Sharp AQUOS Blu-ray Disc Player
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
Hardware & Accessories Logo
26 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
