Question about Mitsubishi WD73727 73" HDTV
Choosing input and "dvd" doesnt play dvd
Tried dvd input and stays on cable channel.
  • 82 Answers
You need to reassign the inputs in the NetCommander
Posted on Jul 25, 2009
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
I have an older sharp tv from an older sibling and the cable works, but I'm trying to connect what I believe to be an older dvd player to it. The dvd player has the 3 color cords (red yellow and white)...
Those modes you gave are for what TYPE of signal is comming in to the Cable/Antenna connector.
You need to switch from that input device to the other input device, the RCA plugs. These are often displayed as Aux or perhaps Line etc. It would help if you had the remote from the tv and were able to choose Aux or Line, or if it has TV/Video button. But if not, try channel button on the tv itself and go down below Ch 1. If using the cable remote to control TV, it may have a TV/Video button too. Maybe.
Good luck
Jun 07, 2011 | Televison & Video
STR-DE835. White noise coming ferom right rear speaker when DVDs are played. Twise the word "PROTECT" has been displayed.
IF any other source plays fine with the RR speaker, and IF it only happens with the DVD player and IF you're using the 5.1 analog audio feeds to the STR, maybe the audio on that channel is **** from the player. You could prove that by temporarily swapping the RR input from the DVD to any other channel input and test it at a medium level.
If it stays with the DVD RR output, the player or the cable would be suspect. Swap in a different cable and make sure it is not routed uniquely near any sources of magnetic fields, motors, UV or track lights, etc.
If you're using digital input all that advice was a waste of time to create as there is nothing external to the chipset that could affect one input channel. Try a different digital input on the STR.
Jan 30, 2011 | Sony STR-DE835 Receiver
I cannot record from tv ? how do you get the channel on that you want to record ? i can dub, play tapes or dvd's, but can't record ?
This model does not have a tuner so you will not be able to record off of tv unless you run your cable box or dish satellite's audio and video outputs through the dvd recorder's front or back inputs(L1 or L2) and record from those sources. Even then the cable box or satellite box would have to be tuned to the channel that you want to record. If you choose to do this you must go to your on screen menu and under setup/general settings/video/video input you will need to select the video input source(L1,rear or L2, front).
Sep 21, 2010 | Magnavox ZV427MG9 DVD Recorder VCR
What channel does the tv need to be on to operate the dvd player? The dvd player comes on but it doesn't recognize the button commands on the tv-do no have the remote.
channel 3 or 4. if that doesnt work switch the input on the tv. the input button might be labelled input/source/tv-video or av. if you arent getting a pic while the dvd player is playing look at the back of the tv and see where the cable from the dvd player is going into the tv. it is labelled what input it should be on. ex: video 1, etc. hope this helps.
Jul 11, 2010 | Philips Magnavox 20MC4304 20 in....
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Dec 21, 2008 | Sharp 32F641 TV
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
Sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Aug 13, 2007 | Sylvania 6427TE 27" TV
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
Open Questions:
See all Mitsubishi WD73727 73" HDTV Questions
Mitsubishi WD73727 73" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
