Question about Garden
I have a hu600f walk behind, after a 87 dollar carb service I had only mowed 20% of my lawn and the engine throttled down to like half power. I do not have a manual...what do I do.
  • 313 Answers
SOURCE: Lawn mower
check out murray & tecumesh website
Posted on May 29, 2008
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
ginocussen
  • 216 Answers
SOURCE: Gilera Nordwest Carb setting
I have a gilera RC 600 which has the same engine as the nordwest, the problem could be the carb needs to be stripped and cleaned and replace the foam air filter with a paper one. For accurate advice and spares which are quickly posted, contact BOB WRIGHT at 0044193451033. He is the official UK gilera specialist, tell him I sent you, say the guy in southern Ireland, and he will look after you. Good Luck.
PS please rate me if this helped
Posted on Jun 26, 2009
  • 143 Answers
SOURCE: 4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Posted on Sep 05, 2009
Testimonial: "Thanks...always get great advice on here...."
SOURCE: walk behind craftsman lawn mower. starts but shuts off
my craftsman 917378490 left front wheel has stopped pulling.
Right front seems ok. Axle is turning on left front from gearbos.
Posted on Apr 13, 2010
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
Tip
What's the hurry
What's this marketing ploy now days about cutting your lawn mowing time in half. I can understand that if u have a bunch of lawns to mow. Beings i only have one, I'm really not a big hurry. Take a look at your yard, do some thinking, and don't over spend. I only want to have to sharpen 2 blades not 3 or 4, and the less drive belts the better. U get your exercise with a walk behind, and get the grass cut too. Last time I was mower shopping, one salesman tried to sell me a 6,900.00 lawn mower. He said it would cut my mowing time in half. I said I'm not buying a mowing that's worth more than my pickup, and for 6,900.00 I could pay someone to mow my yard, and cut my mowing time down to zero.
ballping
on Jul 29, 2010 | Garden
Husqvarna 800 skreetch when mowing
take it backby a good lawn mower like snappeer
Jul 03, 2014 | Husqvarna 21" Walk Behind Lawn Mower HVL...
The engine stops after a half hour of mowing and will not start until it cools down, after which the cycle repeats itself
engine getting hot. Take rope pull off and clean off all the air fins on the cylinder block, use air how and do a good cleaning. If flywheel still have all the cooling fins it should help the problem or even solve it. Keep mower airways clean.
Jun 05, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnmower
It sounds like the throttle cable has moved and in doing so lets the engine run at full revs, follow the cable down the the carb on the engine, the outer part of the cable will be clamped with a bracket and screw, you need the slacken the screw and push the outer cable forward the reduce the tention on it.
Jun 18, 2012 | Black & Decker Garden
Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
May 11, 2012 | Garden
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
8hp Tecumseh engine how to adjust carb. when I put throttle on high it sputters drop the throttle back down its okay?
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Oct 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
