Question about Garden
Just changed my spool on lithium Hybrid - 18V and the string keeps coming out too far and then wrapping around bottom of spool.
    Top Expert:
  • Garden Master
  • 51,259 Answers
Line spool not installed correctly
remove and refit according to the user manual instructions
Posted on May 01, 2017
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Trimmer wrapped around shaft
Deborah there should be a little hole just towards the bottom of the spool head where you could fit a small metal rod in. If you can locate it push something small in like a 2 inch nail and turn the spool head slowly by hand until it locks up. The head should then undo . It will undo anti clockwise.
May 14, 2014 | Black and Decker USA black & decker grass...
Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Dec 18, 2011 | Toys
String is wrapped around area under spool housing
Do not get spool housing off even you got problem such as wrapped string, please go to service center for help.
Sep 07, 2008 | Black & Decker String Trimmer Cordless 12"...
ST 4000 corded
could be the spring, could be not setting right in the spool causeing the spindle to think its being pushed down when its not. causeing it to spit out the line.
check that and if you have another spool kicking around please grab that as well for testing the unit. could also be the spool itself try cleaning that out as well if it looks too dirty.
Aug 10, 2008 | Black & Decker String Trimmer Cordless 12"...
18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
