Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
It pulsates; but pretty much stays in one spot
My G3 pulsates and seems to have plenty of suction. However, it does not move around the pool. The bottom of my pool has a lot of dirt.
    Problem Solver:
  • 4 Answers
Check your diaphram for a tear near the plastic ring that hold it on the tube
Posted on Jul 29, 2009
  • 99873 Jul 29, 2009
    too much suction can this, do you have a flow gauge the flow gauge that came with the G3. hook this to the end of your hose and make sure you have the proper suction.
I've had the same problem. Two things (possibly both of them) might be wrong.
1) You need a new diaphragm (the rubber thing inside). They're about $12 and if the **** in them gets two wide, it won't work properly.
2) Your pressure is either too strong or too weak. Try adjusting it where it plugs into the pool (that springy thing).
Posted on Aug 23, 2009
  • 163 Answers
There might be belts in side one may be broke
Posted on Jul 26, 2009
Why does zodiac g2 pulsate in one spot suction on 1?
increase the flow through the vac by closing off the relief
Apr 24, 2014 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I have the zodiac g3 i hear it pulsating but i looks like it has too much suction and it gets stuck and does not move how do i adjust it
You need to use your pool cleaners flow gauge to test for proper flow. Keeping the hose submerged, attach the gauge to the hose and turn on the pump. The red indicator, when viewed from the side, should be at the 3 setting. If the flow is too low, check and clean the pool filter and baskets. If the flow is too high, verify that valves controlling the suction lines are in the correct position, change your flow setting on the Flow Keeper valve, or open the main drain slightly.
Jul 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
No movement with my g3 baracuda
A small rip or tear in the diaphragm will cause that problem. When you put your hand over the mouth you are creating more suction to the diaphragm. Replace diaphragm.
Mar 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda is pulsating and moving but surfaces
The control should be below the water, and if you cut the suction down that should help with the cleaner.
Dec 22, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Nov 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
668 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
