Question about GE Hardware & Accessories
GE digital timer 15154 The time function works but the timer does not work. Have reset and reprogrammed. The battery shows ok. When the on/off button is set on off the Light fixture is still on.
SOURCE: Olympus Stylus 730 Digital - Won't work 60 days old
I'm having the exact same problem. I was in the middle of zooming on a shot and it froze, so I turned the camera off and on, and now I get the 5-chimes+Zoom Error screen. This is nuts, I've only had the thing for six months, and it was $250 (got the Stylus 730). I *think* I got a replacement plan so that's good. But still... I hope circuit city lets me get a different brand b/c I'm not happy with this now. The only problem I had before was the HORRID shutter delay. I want a model that doesn't have that problem .
Posted on Mar 29, 2008
  • 848 Answers
SOURCE: helps with time - - - - what about date - that doesn't seem to work
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Posted on Jun 25, 2008
  • 6 Answers
SOURCE: setting time/date on old Seiko
Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
Thanks
Kashif
http://VintageDigitalWatches.com
Posted on Apr 02, 2009
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
SOURCE: I do not have operating
Instructions for DT300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Posted on Oct 12, 2010
Testimonial: "Thanks, The user instructions for my Intermatic 7-day Digital Timer ( Model DT300 Series) is just what I needed"
Sylvania sa 140 digital timer
Sylvania timers often come with long warranty. Call 888-548-4484/ hardwareinnovations.com
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Usually if batteries are changed, you want to reset timer. Press reset button, for 5 seconds and then reprogram. If functionality is not restored after reset, then timer has gone bad.
Check outlet for power, makes sure bulb is working, turn light on, try timer on different outlet and with different lamp.
Gene
h
Aug 08, 2013 | Hardware & Accessories
No digital display on my ge 15132 timer
Reset timer and reprogram.
If functionality is not restored, then timer has gone bad.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
GE15132 digital timer from Home Depot has 1 year limited warranty.
Digital timers do not have replacement parts, and are susceptible to power surge such as simple power outage.
Buy new timer at Home Depot, and return defect timer in new package for refund.
Oct 10, 2012 | Hardware & Accessories
It appears the battery is dead, can it be replaced?
Question posted under GE 15079
Open following link to see this series of timers and download possible manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
This series of plug-in timer is sold at Home Depot and has non-replaceable internal battery.
Check power to outlet, and check outlet for problems using circuit analyzer.
If outlet is good, and timer display does not show, then reset timer using paper clip to push in small round reset button located below Hour button.
if functionality is not restored by reset, then timer has gone bad.
Buy another timer at Home Depot and return defect in new package.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 17, 2011 | Jasco 15079 SevenDay TwoOutlet Digital...
The on/off button quit working. I can't manually turn lights on/off. In wall timer ST01AC
Thank you for including timer model number.
You have almond-colored ST01AC timer that worked before and then stopped working.
The manual override no longer turns lights on-and-off.
Manual override works by pushing in timer door, and also by pushing on-off button on face of timer.
1) Try pushing on-off button directly instead of timer door, in case little plastic point on timer door has worn down. If timer door is worn down, maybe add a few layers of tape so door can push button again.
2) If timer on-off button is not working, then timer may be defective -or- timer CR2 battery needs to be replaced, and then timer reset and reprogrammed.
3) Defective timer: timer has 1 year limited warranty against workmanship defect
http://www.intermatic.com/customer%20service.aspx
4) Replace CR2 battery, reset timer, and reprogram timer and see if functionality is restored.
If timer is not restored, then timer is going bad.
Open following link for illustration of battery replacement, steps for resetting timer, and illustrated re-programming steps.
http://waterheatertimer.org/ST01C-program.html#battery
5) Take a moment and rate answer:
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
The timer blinked low battery, we replaced the battery and now it needs to be reprogrammed but we have lost the manual. How do we reprogram it?
You posted under ST01C timer.
Open following page to read ez steps and download manual.
Unless you reset the timer, then programming will still be saved forever.
Even if battery was dead, programming remains saved inside timer until timer is reset or stops functioning.
So all you need to do is set current time.
If the timer will not work, then reset timer.
Mar 27, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I need the instructions for GE 15150 digital timer
The GE 15154 and GE 15150 have same manuals.
Difference between both timer is one has 2-prong outlet and other has 3-prong outlet.
See products at Amazon.
http://www.amazon.com/dp/B0035GAXA8/?tag=picc-20
http://www.amazon.com/15150-7-Day-Plug-Digital-Timer/dp/B0033ZV634/ref=pd_cp_hi_0
Manual for 15154 timer
http://waterheatertimer.org/pdf/GE-15091-Manual-eng.pdf
If this manual does not match your product, add a comment.
Your feedback helps fixya provide accurate and free answers for folks like you.
Dec 15, 2010 | Jasco 15150 7 Day Digital Timer 1 Outlet
GE 15 amp 7-Day In-Wall Programmable Digital Timer Model # 15086 Internet # 100685863 Store SKU # 543414 ------------------------------------------------------------------------------- I...
Your timer is bad. It comes with 1 year limited warranty.
Buy one at Home Depot and then return defective one.
Make note of wiring before removing bad timer, so re-wire is easy.
GE 15086 is White 7-day digital, non-astronomic timer made by Tork, and sold on-line and at Home Depot.
On the shelf, 15086 timer looks identical to 15071 >> same package >>> difference is 15071 offers daylight savings time and random option, and costs a bit more.
These in-wall timers usually last a few years, and some can last for several years.
Especially when timer operates from electric circuit and not battery.
15086 operates from electric circuit.
15086 manual on-line:
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Dec 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My ST01C works fine for a few days and then resets itself. The clock flashes 12:00am every time it resets and their is no pattern to it resetting. Sometimes it works for 2 days; sometimes 4-5. I reprogram...
My guess, it's the battery... Manual has troubleshooting steps that point to battery.
1) Timer requires CR2 battery to work ... double check markings on your battery. Programs will not function without battery. Battery can be low without BATT warning on screen.
2) ST01C has 1 year limited warranty. Things wear out.
3) When reprogramming, do you Reset timer? Or just reprogram Time-Date. Last-ditch troubleshoot says to Reset and Re-program timer.
Oct 02, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
44 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
