Question about Panasonic Lands Phones
Panasonic kx-tgc220 answers on 2nd ring. I have followed the manual and still cannot get it to extend the answering to 4 rings
Slinteriors
  • 8617 Answers
SOURCE: answer too fast
Here is a link where you can download the user manual for free which will explain how to set the phone to answer after a certain number of rings. Just go to the link its already set up just click on the download link.
http://www.retrevo.com/s/Panasonic-KX-TC1743W-Telephones-review-manual/id/2914bh651/t/1-2/
Posted on Mar 23, 2008
  • 64 Answers
SOURCE: how to extend rings on phone before answering machine starts
Hello, here is the link to the manual for that model:
http://www.uniden.com.au/resources_main/pdfs/XSA660.pdf
The information is on page 28
Posted on Mar 06, 2009
SOURCE: Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Posted on Jul 30, 2009
SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
Posted on Jun 05, 2010
SOURCE: no dial tone, rings but cannot answer
Turn off the mains power at the base unit for a few seconds, then turn the power back on.
Posted on Mar 17, 2011
I have a KX-T7433 and would like to change the number of rings before it goes to voice mail. It is currently set at 4 rings and would like to change it to 6
The KX-T7433 isn't an answering machine. If the voicemails are going to an answering machine you have on the phone line, consult its manual. If the voicemails are going on to your telephone service provider's system, look for instructions in the phonebook, or contact the provider.
If you need a KX-T7433 manual, you may download a copy at Panasonic KX T7433 Phone User Manuals Guides
Oct 29, 2016 | Panasonic KX-T7433B Corded Phone
Answer too fast
Mar 23, 2008 | Panasonic KX TC1743W Cordless Phone...
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
Extend ring time
If by extending ring time you mean increasing the number of rings before the machine picks up, there should be a selector switch somewhere on the base of the phone or hidden under a panel
Dec 26, 2012 | Panasonic KX-TG7622B Cordless Phone - Dect...
I have a panasonic KX-TGA410C phone and would like to change the number of rings before answering machine comes on.
it's so easy friend just dial *94 and hit 4 or 5 or 6 upto 10 ring numbers
for example *948 dail... will give u 8 ring count before voicemail start
good luck
Dec 18, 2012 | Panasonic Lands Phones
I can not locate how to limit the number of rings; and the answering machine does not come on even after 20 rings; I can hear my message recording- when I play it back; but it does not come on for incoming...
Ring count You can change the number of times the phone rings before the unit answers calls. The default setting is "4 rings". "Toll saver": The unit answers on the 2nd ring when new messages have been recorded, and on the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages, you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 {MENU} 2 {V}/{^}: "Answering device" i {OK} 3 {V}/{^}: "Settings" i {OK} 4 {V}/{^}: "Ring count" i {OK} 5 {V}/{^}: Select the desired setting. 6 {OK} i {OFF}
MANUAL http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
HOPE IT HELPS GILES102
Jun 27, 2011 | Panasonic KX-TG1033S Cordless Phone
Hello friends from FIXYA, I have a situation where I cannot get my Panasonic KX-TA824 pbx to answer incoming call at the fist ring using DISA. I have tried everything and I cannot get it to work. DISA...
And??? What's the problem? My DISA is set for 1s on the first page and it never rings a phone. If you want it to answer the outside line on the first ring, you'll have to turn OFF Caller-ID. Now it will answer right after the first ring, but you lose CID logging.
On my working system, the DISA 6.1 section is with AA and 1 second, and 6.2 the first two timers are 3 and 5 seconds. In 9.1 you can uncheck CID but I don't recommend it.
Carl
Sep 22, 2010 | Panasonic KX-TA824PK Phone
PHONE CUTS TO MESSAGE AFTER 2ND RING. I WANT IT
if answering machine is on phone , go to messaging menu it should have a setting for number of rings... make sure toll saver option is off!
Nov 08, 2009 | Panasonic Lands Phones
Set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
Feb 02, 2009 | Lands Phones
Answering system
my answering machine light blinks but the machine isn't working.
Dec 17, 2008 | Panasonic KX-TG1033S Cordless Phone
Lands Phones Logo
54 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
