Question about HP Computers & Internet
My HP notebook wont connect to internet unless im next to router. what do i need to do to be able to access internet in another room
  • Brett Duxbury
    Brett Duxbury May 01, 2017
    Hi Pamela Norman, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    how is hp notebook connected to router ?
    What is make and model number of router ?
    Is hp notebook got wi fi 802.11 BGN or 802.11 ac ?
  • HP Master
  • 2,007 Answers
What notebook (model
what router,. name and model , endless choices here.
the router can be bad, how old is it, ?
what room, how far.? 10ft, 100 feet? distance matters.
is home wood, or concrete walls or brick walls.
the RF energy is weak and does travel far.
unless only air is between point A TO B.
Ever drive into a tunnel and have radio go dead, same thing happens here.
as you walk , look at the signal strength. see it drop
the lower it goes, the slower it goes.
or you are using same channels are your neighbors.
use the program to learn how to stay off busy channels.
the rounter
insidder 4,
learn how wifi works then play with this magic tool,
I run my channels where others are not.
Posted on May 04, 2017
SOURCE: cannot access internet with wireless router connected
powercycle the belkin router and modem and computer..
Posted on Jan 18, 2009
  • 366 Answers
SOURCE: Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Posted on Jan 20, 2009
  • 135 Answers
SOURCE: Need to set up router without the CD
Connect one of your computer to LAN port 1, connect the modem to port WAN section, access the configuration page, configure the router as dynamic IP address under settings, then check the IP address under status (WAN section) if you have the IP address it means that your connected.
Posted on Mar 16, 2009
  • 287 Answers
SOURCE: Toshiba does not connect to wi-fi unless other laptop is on wi-fi
1. Reinstall the wireless driver.
2. Restart your system.
Posted on Jan 04, 2010
  • 825 Answers
SOURCE: N1 Belkin to HP notebook - connection speed drops to 24mbps
It might be because of other electronic devices that works nearby in similar frequency...devices lik microwave oven, inverters, modems provided by the ISP which comes along with a battery backup, especially RCA modem which doesnt allows other wireless devices to work nearby it... try to relocate the router to a well ventilated area, and make sure you have kept the router atleast 5 feet away from other electronic could help....
Posted on Mar 29, 2010
Is there a default password for belkin routers? My roommate has the router in his room and out of the country and I need internet. Is there a way I cam access the guest belkin with a default password?
Hi, Why not contact your room mate and get the password from him? In the meantime, if you are looking for access to the Internet for free, most Council Libraries offer internet access at no charge to card holders.
Apr 26, 2016 | Belkin Computers & Internet
Factory reset
Hello there!
check these:
Go to another place, that has wifi access and check, if you can go into internet, or reset your wifi home router.
other thing that sometimes block internet access is your antivirus, or firewall, verify those.
Oct 07, 2013 | HP Compaq Presario C304NR Notebook
My laptop wont stay connected to the internet
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Jan 27, 2012 | HP Compaq nc4200 Notebook
Have a dv6-136 1sb hp pavilion Entertainment pc. i am able to access the internet via wireless internet access when i am close to the router. however when i go three rooms away i get no internet access. at...
The issue here may not be the laptop but the router strength of it's wireless radio. Do you have another laptop or a freind who can come over and test his connection? The DV series laptops have pretty decent antennae and wireless cards. Try to update the drivers for the WLAN card, make sure the antennae leads have a good secure fit at the ends where they attach to the card. If the router is a couple to several years old, it may need the firmware updated.
Jul 05, 2010 | HP Pavilion dv6000z Notebook
Wireless Connection
The WPA code is the password to access the router's network, so it can use your internet connection. As long as the Xbox has both the SSID and the WPA password, it can access the internet through the router.
The SSID ( Chris_PC_Network ) is mostly irrelevant to the network connection, and is purely aesthetical. Its only use is to help users distinguish between different networks (so you don't use a neighbor's network or vice versa).
May 24, 2009 | HP Pavilion dv6000z Notebook
Problems with internet connection have got wifi
Dude, there is no way you can get a better signal unless you come closer to the router or the router comes nearer to you. I suggest that you get a new source of internet connection
May 02, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
Internet problems could use some help.
A neighbor's connection could very well affect you. That's what I think your problem is. Now, to be honest, a 36mbs connection is pretty darn good. It's rare that an application would require more. Even a video streaming solution will work fine over that kind of connection. My professional opinion is, not to do anything.
Apr 03, 2009 | HP Pavilion dv6000z Notebook
Bought a router to connect home line with new notebook
Umm, maybe you didn't plug it in right. Try putting in the CD rom of your router, then download it, and it will probably have setup/ help on there.
Dec 28, 2008 | Computers & Internet
Turn of wireless
If you use your cable internet service via an ethernet cable, basically plugged into it directly, then there is no way some one can access your internet. If you have a wireless router in your house, someone can use your router for a connection if they are within range. Unless you router is set up with a network key (password) in order to connect. A network key is set by you and only you have it, so if you set one write it down, if you lose it you will need another router in order to connect other machines in the future. Also, a network key only needs to be entered into a computer once, it's not a password that is entered every time you log on, the network configuration in the computer remembers it. Now keep in mind that "hackers" aren't interested in individuals (unless you're a major corporate ceo or somthing), and even if somebody does access the internet through your service that they cannot access or see anything on your computer that you don't allow them to see or access, that security is built in. Don't let Dateline scare you about "hackers", I saw that episode and they made a mountain out of a mole hill, bad. If you have any other questions or concerns, feel free to ask.
Jul 03, 2008 | Acer Aspire 5050-3242 Notebook
I cannot get my new computer to recognize the linksys router I have Model No:WRT54G
do a search for linksys easylink advisor. it will guide you through setting up your second computer.
Feb 17, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
