Question about Crosman Optics
Where can i get a Crosman 622 barrel stock?
I have a Crosman barrel that is broke. I cannot find one anywhere.
How to install crosman 795 part no. 10448
The Crosman 795 Detent part #10448 is "press fit" into the rear end of the barrel therefore you can use a flathead screw driver, place it between the plastic detent and the steel barrel and gently wiggle and pry the dentent off.
Jul 05, 2014 | Crosman Phantom .177 Caliber Break Barrel...
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
Jan 30, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Gun wont stay locked when i **** it bak
I had the same problem, it wouldn't click or stay c.o.c.k.e.d when I did a typical barrel break. I took apart the back end where the3 spring was. (screw and pin must be removed once you take the barrel out of the stock.) I found that it was the "Back Spring Guide" that was broken, but not completely, I turned it, put it back together and it worked for about 9 more shots. Then the same thing happened, so I know that I need a new one. Here is the Part # B18‐00‐6 here is a link to the part breakdown pdf from Crosman's site.
http://www.crosman.com/pdf/manuals/C1K77%20C1K77X%20%20EVP%20&%20PL.pdf
I just called customer service at 1-800-724‐7486 but they close at 4:30pm eastern time, I left a message.
I cannot find anywhere online to buy that specific part, so I assume that it has to come from Crosman. I'll let you know how I make out.
If anyone knows where to get Crosman parts, please let me know.
Thanks
MD
Aug 05, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
Jul 29, 2009 | Crosman (4032)
I had broke the front aim sight. Can I recover it?
you could contact thecompany that make this gun and ask them if there is anyway to replace the broke front aim sight
but most likley you wont be able to replace it and just have to buy a new one
Jun 24, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Will not pump up in order to fire
open the pump handle and spray a little WD40 into the piston tube and let the gun stand **** down for an hour or so. close the handle and try again. It seems the piston sticks and then separates from the linkage in the pump handle.
Apr 03, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
Top Crosman Optics Experts
Martin Clarke
Martin Clarke
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
