Question about Garmin StreetPilot c340 GPS Receiver
UNIT WILL NOT TURN ON
THE UNIT WILL NOT TURN ON.WHAT COULD THE PROBLEM BE? THEUNIT WAS O.K THEN LOW BATTERY APPEARED IT SHUT OFF AND NOW WON'T TURN ON.
I had this happen, my cord was unplugged, and I didn't notice till I got a low battery...then volume went down, and poof. would not restart. After some Googleing I found that under the bezel, or face around the screen, is a reset button. Recharge for a little while, press reset and it will return to normal. To remove the bezel, just pry up gently, starting right under the Garmin name.
I don't know why they hide this reset!
Posted on Aug 06, 2009
    Brigadier General:
  • 4,090 Answers
This is a common occurrence with a lot of GPS units. The battery has reached critical low and as such has shut down. You should connect it to the AC charger and leave for an hour or so to build up sufficient current to allow it to turn on and display. If this is not the problem, it is possible the battery has collapsed and will need replacing But try the ACcharger first
Posted on Jul 25, 2009
Phone won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 26, 2012 | Motorola Cell Phones
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
I have a mini 7 inch epc netbook. I first turned it on and it worked fine. Then a message box appeared saying the battery was too low and it shut down. I plugged in the adapter but it still won't turn on....
The battery is low on charge or shorted inside and won't take a charge dragging the voltage down so that even the battery charger won't start your computer.
Change the battery with new and charge with a known good charger.
Jul 04, 2010 | Computers & Internet
Vertical colored lines have appeared in my display.
turn on the system by pressing FN key and then the power but this should start up the onboard diagnostics let me know if the line are displayed during the diagnostic if it does the its the graphics. when it ask you if vertical or horizontal bars were displayed. select N so it can test the LCD panel if the lines are displayed there then it is your lcd panel.To make sureyour lcd panel is fine it will display solid colors.
Jan 20, 2010 | Dell Latitude D510 Notebook
Have a coleman evcon heating & cooling furnace froze up had ice on coil / top of unit. Husband cut the unit off to thaw out not the unit will not come back on.
Freon (charge) is low. Contact a service man with the proper gauges to check theunit. It will have to be evacuated, nitrogen pressure tested, and then recharged.. Depending on the size of the unit, this cold be about 200-400$.
Jul 07, 2008 | Heating & Cooling
Battery can't charge
You all need to get the latest firmware upgrade from Sansa's website.
Apr 13, 2008 | SanDisk Sansa Clip MP3 Player
Not working
Operationg instructions says it is "F 70". When it appears it says to turn the unit off, disconnect the aC power supply cord, then reconnect and turn theunit on. Consult your dealer if "F-70" remains on the display.
Mar 30, 2008 | Technics SA-DX1050 Receiver
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Garmin StreetPilot c340 GPS Receiver Logo
458 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
