Question about Sanyo Televison & Video
My 52" Sanyo flat screen TV has a snowy white fuzzy picture to it I can see everything but it's very snowy white fuzzy picture how can I fix it
    Top Expert:
  • Sanyo Master
  • 75,025 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Posted on May 02, 2017
Just bought a 55" DP55D44 Sanyo TV, and the picture seems to be showing fuzzy. How can adjust this?
The fuzziness is radio noise from space. No I am not kidding. It's from the background radio spectrum of the universe's creation and it is uniform and OMNI-directional, so it will always appear as snowy noise that is fuzzy in appearance. You can't remove this noise unless you connect a signal from a TV station or cable that is much stronger in strength than this noise. If you mean that a TV signal comes in and appear fuzzy, it is because this TV signal is very weak and you need a better antenna to increase the signal gain. Hope this helps.
Jan 02, 2015 | Sanyo Televison & Video
Snowy white picture while on cable.
Maybe a tuner problem--considered hooking up whatever you use for signal to the rear av jacks? bypass the problem?
Apr 06, 2012 | LG 50PC5D Television
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
You try to play the video tape or DVD. If picture still snowy, the picture tube is getting old. Buy a new one, do not repair it will cost almost a new set.
Aug 12, 2009 | Acer Aspire One AOA110-1588 Notebook
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
White screen
I called sanyo ,they had me try this and that and then said a tech guy would call back he did i am taking the tv to a repair shop and it will be fixd under the warranty.
Jan 11, 2009 | Sanyo DP23625 23 in. LCD Television
Sanyo 27" Problem: Fuzzy Screen
sanyo does this alot it is either you need to replace your tuner or you have two resistors 220k ohm s that need to be replaced.this will fix your problem.if repair cost is cheaper to fix then buy a new one its up to on that one!
Dec 01, 2007 | Sanyo DS27910 27" TV
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
73 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
