Question about The Home Security
How do you wire a front door button to ring a doorbell inside and another bell on the back porch?
    Top Expert:
  • The Master
  • 47,675 Answers
Wire in parallel that is the positive wire from the button to the positive terminal of each bell and the same with the negative wire
Posted on May 01, 2017
Craftmade CA3-RC Artisan Door Chime
AC is likely to be the alternating current supply from the transformer.
I suspect two pairs of AC terminals are provided to allow one of two different chimes to be selected with one pair and the common being used for the 4 chime pattern and the other pair and common used for the 8 chime pattern.
The front, side and rear terminals are self explanatory connections from each bell-push with the supply (or return) or other wire from each bell push connected to the COM or common.
The manufacturer's website doesn't feature a wiring diagram though might send you an instruction book on demand. The site does include a note specifying only 18 gauge wire is to be used...
Dec 10, 2017 | AC Cars & Trucks
When our neighbour's wireless bell is rung our wireless bell rings as well
Open up the back of your bell and the back of your button. There should be switches you can move. Just move them the same on the button and the bell. This will make it so yours doesn't ring when theirs does.
Sep 11, 2012 | Heath Zenith Designer Series...
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Installation of wired doorbell
yes it is very simple. All you have to do is connect either the two red wires together or the two black wires together and put the other remaining two on the doorbell chime to the common and front terminals. Here is how it works. One red wire leaves the transformer. It connects to the other red wire going to the pushbutton. When you press the button the voltage comes back to the bell on the black. You have the other black from the transformer on the bell so that completes the circuit. The only reason I say to put either the two blacks or two reds together is that way you're sure to have one wire from the transformer and one from the doorbell. Not a 'pair" of wires from each. 5ec779c.jpg
Jul 11, 2010 | Hammering
New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
Mar 15, 2009 | Honeywell Electrical Supplies
Home Security Logo
43 people viewed this question
Top The Home Security Experts
vince
Lawrence Oravetz
Are you a The Home Security Expert? Answer questions, earn points and help others
