Question about Home Security
How to wiremodal # BC8170 aELECTRIPAX motion detector light up?
frcs68
  • 1605 Answers
SOURCE: Electrical hook up for 2
yu can't do it with off the shelf detector. Sine the detector is single input.
you need serial and parallel input to the device.
you need to get commercial detector that haev serial and parallel input to the detector.
Posted on Dec 30, 2008
SOURCE: Heath Zenith #SL-5316 Motion detector light what are settings?
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
Posted on Jun 16, 2009
SOURCE: Since the VEO motion detector is no longer
The motion detector is available new on Ebay right now from an electronics surplus dealer. Just type in 12v motion as your search and at least half a dozen come up. I bought one and it was new in the box with the instructions.
Posted on Oct 17, 2009
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Posted on Jan 29, 2010
  • 16 Answers
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
Posted on Apr 13, 2010
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
Hampton Bay 7828 Outdoor motion detector lighting for the driveway
Please an you send a pick of the unit when it's open on the input so we can go trough without Manuel as it's just a lux adjust ment
Sep 27, 2016 | OUTDOOR Home Security
As per request. re: reset/fix indoor motion detector.
on all the Honeywell or Ademco wireless motion detectors I have worked on the light will not come on with the cover in place, it is set that way to conserve battery life. If you want to be sure it is working properly arm your system and wait at least 4 minutes before walking in front of he motion then walk in front of it and see if it trips the alarm.
May 05, 2014 | Honeywell Ademco Apx32en Alarm System...
How to reset/fix an indoor motion detector?
Depends on the model of the detector, but wireless motions are not supposed to light up; if they light up they have been put into test mode, either by opening the tamper switch, removing and reinserting the battery, or by positioning an internal jumper to the test position. If the motion is a 5890(PI), remove the batteries and short the empty battery sockets for about 30 seconds to reset the low battery circuit, then reinsert the batteries and close the cover, making sure the tamper switch is properly closed. Other motions don't need this reset procedure, but do need all tamper switches closed. Ensure no one is moving near the motion and reset the keypad by entering your code plus Off (just like coming home). If everything is right and all other devices closed the ready light should come on.
May 01, 2014 | Honeywell Ademco Apx32en Alarm System...
Hi my question is motion spot light has has two black wires one from each light and two white from each light and one red from the motion detecter which is connected to the black wires there are two wires...
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Dec 18, 2010 | Home
How to wire a cooper industries 6107 3-way motion detector switch
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Lights only work in test mode sensor picks up motion
You are talking about a motion detector attached to some type of light I presume. Your numbers mean nothing, I'm sorry to day.
Very first consideration, you do have it correctly wired, right? White to white - black to black - green to green and ground. The red goes to the lamp black wire, right??? (Light White goes to neutral (white line))
I am very familiar with motion detecting lights, working at a large resort at the seashore.
Two conditions that must exist for this light to come on ... it must be dark and there must be a motion. There should be two adjustments on your detector; one is for sensitivity and the other is time the device should remain on.
Dark ... not just sundown ... are there other lights in the area that may cause your detector to think it is day time?
Sensitivity. On minimum sensitivity, your detector is nearly blind to any but the closest movements. On maximum, it will probably see bats flying by. You must adjust to meet your needs.
Does it have a warranty? I dont know. You would have to check the information that came with your light.
I hope this information helps you ... Positive comments are appreciated.
Thanks for clarifying your question and thanks for visiting FixYa.com
a
Oct 27, 2009 | Electronics - Others
Electrical hook up for 2 motion detector lights so both lights operate when either detector is activated (dual master system)
Dec 15, 2008 | Solar Motion Security Light Conversion...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
