Question about Manitowoc Kitchen Appliances - Others
How can I remove my Manitowoc ice maker fan motor
fridgetech
  • 473 Answers
SOURCE: ice maker LG side by side
What is the model #? Get it off the sticker inside the refrigerator side.
Posted on Oct 08, 2007
  • 3 Answers
SOURCE: Ice Maker Motor replacement
I was able to remove the motor module by pressing together the two tabs that held the left arm of the shut off bar to the motor module. I purchased a new KitchenAid motor module (substituted a part by the factory). I replaced the motor module and I now have ice making again. The only difference though is that with the new motor module, the on position with the shut off arm is know longer in a 3 o'clock position but more a 5 o'clock position.
Posted on Aug 03, 2008
  • 219 Answers
SOURCE: ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Posted on Mar 19, 2009
  • 29 Answers
SOURCE: I have a manitowoc QY0424A ice maker and the water
Turn back the pressure on the water going into your home and or if there is an adjuster on the back of the fridge set it for 1/2 less.
Are you in a house or a flat?
Posted on Mar 20, 2010
diodeic
  • 1622 Answers
SOURCE: Kenmore model 3639550610.
If fridge repair because it is noisy, turning off and on, or running all the time, it could be a sign the condenser fan motor is going bad. Thankfully, this type of repair is not as complicated as some may think. You can check the condenser fan motor yourself and replace it if necessary.
Tools and Materials Needed:
* Multitester
* Screwdriver
* Needlenose pliers
Step 1 - Disconnect the Power
Turn off the power to the refrigerator to prevent electric shock.
Step 2 - Remove the Condenser Fan Motor
The condenser fan motor is located on the bottom of the fridge, most likely toward the back. Heat from inside the fridge is released into the air here. A panel will probably need to be removed to access the motor. Depending on the screw, a screwdriver or nut driver will be required to remove the panel. Find the condenser fan and motor. You can quickly check the fan's operation by seeing if anything is obstructing its rotation. Manually move the fan blades to see if they spin freely. If they do not, you may need to replace the fan. Continue removing the condenser fan motor by taking out the screws that affix it to the mounting bracket.
Step 3 - Test the Condenser Motor
Your condenser fan motor will most likely have 3 wires attached. Some models have just 2. Note which wires are connected from the fan to the motor. Use needle-nose pliers to remove the wire connectors from the motor. Be careful not to damage the wires. After the connectors are removed, use the multitester to check the resistance or passage of electrical current. Set your multitester to ohms.
If the condenser motor has 3 terminals, only the outside terminals need to be checked. The inside one is a ground terminal. Check the terminals by using the multitester probes, touching one probe to one terminal and the other probe to the other terminal. The reading should fall between 0 and infinity. If you reading falls on either 0 or infinity, then the condenser motor is bad and will need to be replaced.
Step 4 - Replacing the Condenser Motor
Condenser fan motors can be ordered from the refrigerator's manufacturer. Once you receive the new motor, check it with your multimeter the same way as the old motor. This will make sure the new motor is in working condition. Attach the wire connectors to the new motor in the identical locations as the old one. You can refer to the new motor's wiring diagram (most likely included with it) if assistance is needed. Now install the new motor under the fridge. Attach it to the mounting bracket using the same screws as before.
Step 5 - Testing the New Motor and Keeping it Efficient
With the new motor connected and attached, turn the power back on. The unit should operate correctly. If it does not come on, check the wiring. Dust and dirt can plug a condenser and affect the fan's ability to discharge heat. Cleaning them several times a year will help the fridge run efficiently.
Hope this help in solving.take care....
Posted on Sep 18, 2010
Ice machine manitowoc gets stuck when full of ice why?
Service Literature Downloads - Manitowoc Ice
www.manitowocice.com/minisite/service/servicedownloads
Manitowoc Ice has a complete library of service documentation offered in two different formats. First, Interactive Electronic Document Catalog (EDC). Second .
Aug 25, 2015 | Kitchen Appliances - Others
Manitowoc troubleshooting
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
The pump in my ice maker is noisy and I wonder what is the best product to clean it.
Is it the pump or the motor on the pump making noise? If motor then you need to replace the motor/pump assemble. if it is scale build up then you can try a scale remover scotsman or manitowoc nickel safe cleaner.
Oct 23, 2013 | Kitchen Appliances - Others
Won't make ice in cold weather
Check the thermostat of your Ice maker whether it is in working condition or not. For More information please visit GE Ice Machine Cleaner.
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
I HAVE AN MANITOWOC Q SERIES CVD 2075 UNIT RUNS FOR 30 MINUTES AND ONE OF THE DUAL FANS CUTS OUT CAUSING INSULATION TO BURN OF HOT GAS LINE PLZ HELP
Sounds like a bad headmaster valve, bad fan motor, or bad pressure cycling switch for the fan motor. Will need to know operating pressures to troubleshoot. Not really a DIY job unless you have some experience.
Sep 29, 2010 | Manitowoc MAN-CVD2075 Condenser Unit...
Condenser motor cuts out and causes insulation to burn off hot gas line why?
you mean the fan motor? if power cuts out to it, check sensors or the board. if power is there, replace the motor
Kitchen Appliances - Others Logo
67 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
George Merkley
George Merkley
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
