Question about Maytag Refrigerators
Maytag SS French door bottom freezer. Model MFI2569VEM4 We recently had a power outage due to a storm; but when power came back on the computer panel did not.
  • 66 Answers
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Posted on Feb 07, 2008
HVACRH20
  • 237 Answers
SOURCE: Jenn-Air JFC2070KRS French door bottom freezer model
The panel on the inside back wall.
Posted on Jul 03, 2008
  • 262 Answers
SOURCE: Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Posted on Jan 08, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer door hard to open.
Here is so Q&A's that ma solve your problem. Click on link below to get a lot of resourses and answers. As for the home owners insurance may be no. Let me know if this helped you.
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 02, 2009
  • 1122 Answers
SOURCE: Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Posted on Mar 15, 2009
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
We recently moved and our Maytag French door ice maker was working fine when it was loaded on the moving truck, but when we plugged it back in it is no longer working at all. Any suggestions
after moving any frig / the fan underneath may have insulation in it or things bet bent causing the fan not to go . this would cause poor cooling and if freezer is not cold enough the ice maker would not work . ck the tempt in freezer / must be 15 deg or lower . and the fan could cause this problem also wiring on the bottom ..mm
Aug 03, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer icing up
Experienced this problem with Evaporator coil icing up (coil is located inside back wall of the freezer compartment; the ice/frost was visibly blocking the series of louvers or slots along the bottom of the freezer back wall. I think the power outage caused partial melting of an already somewhat iced coil, but when the power was restored the water on the coil just froze solid. When these slots become obstructed the Refrigerator will not cool to its proper 36-40 deg.F temperature and the compressor motor runs frequently and the noise level is louder than usual. SOLUTION: fastest and safest way to Defrost this iced up coil is: (1) turn off 120V power / unplug refrigerator from the outlet; (2) remove all food to another refrigerator / freezer and take out ice cube tray & flip icemaker bail wire to its up (off) position - but leave top freezer basket in-place; (3) remove Bottom freezer basket (which should lift up and out; (4) move refrigerator away from wall - and carefully unscrew and remove white-painted, rectangular metal panel at bottom in the back....... you will see a white plastic water tray below a small fan with black plastic blades...... have a 3x5 cellulose sponge and bucket handy...... (5) open freezer door all the way and set a 21-inch box fan on the floor in the opening or area where the Bottom freezer basket was removed... put a single towel on floor under the box fan if there is significant frost on the bottom of the freezer compartment (there should not normally be any); (5) turn the fan to "Medium" speed with air flow pointing toward the freezer... you will be amazed at how much faster this works than pans of hot water or hair dryers (the latter is potentially damaging and dangerous); (6) with a flashlight you should soon see the water drip-drip-dripping from a spot at the center and bottom of the Evaporator coil - where it goes down a white tube and into the white plastic pan beneath the small fan you saw in Step #4; after awhile (maybe 20 minutes) check the white plastic tray in the back - which will be full of water (sponge it out)... continue defrosting with the 21-inch box fan... check the plastic tray again - and sponge out the excess water. A completely iced-up coil will probably fill the plastic tray three times. Eventually the water will stop dripping - which means the Evaporator coil is completely defrosted. There may be some water that gets onto the floor under the left side of the refrigerator which you will have to wipe up. Reattach the metal panel and reinstall the Bottom freezer basket and ice tray. This process takes long enough that you can clean the inside of the refrigerator while you're at it.
Jul 09, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Have a maytag french door bottom freezer. Top
try unplugging the unit and use a blowdryer to defrost the return air ducts, they tend to freeze up, they are located on the rear wall of the freezer behind the panel. with doors open and unit unplugged, introduce warm air for a couple of hours
Nov 07, 2009 | Refrigerators
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HES
check your thermostat setting. you could have set it too low. if not , you can see and check if it uses a duct thermostat where in it supposed to close the duct if the temperature of the cabinet is already cold. it may be stuck open.
Feb 04, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
49 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
