Question about RIM BlackBerry Curve 8310 Smartphone
8320 shuts down in the middle of calls or rather does a restart as if you press alt shift delete keys. Only happens when talking on the phone. Happened maybe once a month for the first few months and getting more and more frequent. Updated software three weeks ago and still does it. Any help is appreciated!!
  • notabiker1 Jul 25, 2009
    Will try, I have a 8300 and spare battery for it but the wife's 8320 is 6 months old and she lets the battery go almost dead if not dead before recharges so I don't know if that changes anything. She can surf the web on it as much as she likes but only calls make it restart.
  • notabiker1 Jul 26, 2009
    Nope not the battery, switched it for the seidio battery I use and did the same thing 3 minutes into a call.
    President:
  • RIM Master
  • 2,923 Answers
Once the BB 8320 shuts down in the middle of calls, more likely it's the battery. There were times that you would see that the battery is fully charged, but once the call comes in, the battery is starting to discharge quickly and unexpectedly.
And after it dies, it would try to re-gain a small amount of power. But you need to isolate the problem, try using different battery to test it. Some repair shops let customers use their spare batteries for testing purposes.
Or contact Blackberry manufacturer for second opinion.
Have a great day!
Posted on Jul 25, 2009
  • Melvin Ramos
    Melvin Ramos Jul 26, 2009
    Yeah that's a good thing to do. It's much better to make sure that the phone is running low battery before charging it.
    The battery would not last long if you charge it while it has still charge. Making sure that the battery is low before charging it is the best thing to do.
    Thanks for your reply.
  • Melvin Ramos
    I would advise you to contact the manufacturer for second opinion.
I held the shift key down longer than normal and now am unable to type double letters, backspace, or use arrows.
Restart your computer to turn off the "Sticky Keys" accessibility tool.
Use "sticky keys" if you have limited finger dexterity capability or limited motor skills.
For example, you can press CTRL and then ALT and then DELETE,
rather than having to press all THREE keys at the same time.
Apr 09, 2011 | Compaq Keyboard
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
How do I reboot my acer laptop
Reboot simply means to turn it off and start it up again...you do this by shutting it down and starting it back up later, or choosing restart from the shut down menu.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 05, 2011 | Computers & Internet
How do I re-boot my acer AO532h computer?
If pressing down and holding the control (ctrl) key + alt key + delete (del) key together doesn't let you reboot, you should be able to hold down the power button until your PC shuts down. Then you can simply press the power button again to turn it back on.
If all else fails, unplug the unit from the electrical outlet and remove the battery. It will shut down. Put the battery back in and restart.
Oct 14, 2010 | Computers & Internet
How to reboot
1)Go to Start > Restart.
2) Press Ctrl+Alt+Del and Choose Restart option.
Sep 25, 2010 | Toshiba Satellite A205-S4617 Notebook
Exactly the same problem. I missed so many calls because of that
I have a Bold personally and try a soft reset. You won't lose any data but press the alt key on the left, the shift key on the right, and the delete key on the right simultaneously. This is like control-alt-delete on your computer.
Sep 29, 2009 | RIM BlackBerry Bold 9000 Smartphone
I want to delete old text messages, how do I do this?
go into message menu highlight message press the menu key(next to talk button) should give you several oprtions scroll down to delete the press trackball should prompt DELETE ITEM select delete all done
Mar 23, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Vpr matrix 1.8 mhz will not boot
press only the delete key restart hold the delete key
Mar 14, 2009 | Matrix 226R (VPR226R) PC Desktop
I can't dial out.
The Phone application on the BlackBerry smartphone automatically converts phone numbers that include letters into the associated numbers.
To key a phone number that contains letters, press the right Shift key or the Alt key and type. The letters appear on your screen, but the BlackBerry smartphone translates them into the appropriate numbers when the phone call is made.
For example, to call 1-877-BLK-BERR (1-877-255-2377) from your BlackBerry smartphone,
  1. Open the Phone application.
  2. Type 1877.
  3. Press and hold the Alt or right Shift key and type BLKBERR.
  4. Display the menu and select Call 1877BLKBERR or press Enter. When the phone number is dialed, the letters are converted to numbers on the screen.
  5. To end the phone call, hold down the Escape key.
To return to the Home screen from any other screen, press the End key.
To lock the device, set a password. Hold the * key.
To unlock the device, press the * key. Click Unlock. Type your password.
To lock the keyboard, hold the * key.
To unlock the keyboard, press the * key
To switch the input language, hold the Alt key and press the Enter key. Continue to hold the Alt key and select a language. Release the Alt key to switch to that language.
To switch back to your original input language, press the Alt key + the Enter key.
I hope this helps
Please remember to rate this solution.
Sep 21, 2008 | RIM BlackBerry Pearl 8100
How to recieve MMS video on my Blackberry Curve
press Alt+LGLG. This opens your event log. Ignore the warning, press the blackberry key, and choose clear log. Restart your phone with alt+right shift+delete. Have the MMS resent, and you should get it.
Mar 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
326 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
