How do you clean the inside gasket I have tried cleaners but none get into the inside, it really stinks
    Sergeant:
  • 111 Answers
I am very familiar with this as well - your HE washing machine should have a "clean" cycle that allows you to run this with only bleach. Does the trick every time. Sometimes, you may need to do this more than once. Make sure the water is on the hottest setting. There are other DIY ways found on this link if you do not have a clean setting. You could also just run the washing machine with bleach without any laundry in it as well. HTH
How to Clean High Efficiency Washing Machine Ask Anna
Posted on May 01, 2017
4 Suggested Answers
  • 198 Answers
SOURCE: my washer stinks. I've cleaned the rubber gasket,
It sometimes helps to use automatic dishwasher detergent in the machine with no clothes in it, with hot water. Also be sure to use HE dertergent
Posted on Oct 23, 2009
Testimonial: "Thank you."
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Front loader washing machine stinks really bad
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
richroth
  • 9472 Answers
SOURCE: machine stinks of stale milk gave a really good clean but stinking kitchen out please help.
Is this a front load?
Posted on Nov 05, 2012
My Duet washer stinks so much. The wash does not come out smelling good. It is clean but it doesn't smell good. I do use those cleaning tablets but it still stinks. It has over-suds many times where...
I have found that using a l/4scoop of oxi cleaner any brand will do along with my regular wash detergent helps keep the odor under control . I leave my door open to the washer when not in use. Occasionally I will clean under the gasket with a mild cleaner. Remember the front loaders use less water and therefor less detergent. Good luck.
Sep 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Is there a gasket betwen transmision and 4x4 gear box on k1500 1990 chevy? There was none when taking apart. But is leaking fluid now
Clean really well of all dirt, oil and any other foreign material (both mating pieces) then clean further with either carb cleaner or brake cleaner. Seal back with good quality silicone.
Jun 19, 2010 | 1990 Chevrolet K1500
Drain has a terrible odor. Tide cleaner cleaned
Try Baking Soda down the drain. It's a very good odor absorber.
Aug 16, 2009 | Plumbing
Mould on gasket inside door
u need to clean the door seal with a cream cleaner then put the machine on a boil wash with soda crystals in it or but the lime and gunge descaler from espares
Jul 29, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My washer has an odor like mildewing clothes, but I can't find any.
all front loaders are good for that, none of the manufactures have really found a solution to clothes stinking like that
Jun 23, 2009 | Whirlpool GHW9200L Front Load Washer
Stinky clothes
you should run a empty load with bleach but no detergent every month or so to clean the washer, I also recommend cleaning the boot (door gasket) every couple of loads with windex or other cleaner. also every load check inside the bottom of the boot and make sure the drain holes (x3) are clear of lint, etc. this is normal maintenance for any front loader. GE is a very good brand and is my preferred brand, I repair appliances everyday, Whirlpool keeps me busy. I have GE front loaders in my house.
2nd poster, you will need a door hinge for this most likely. Not too hard.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our front load washer stinks like stale water inside. How do we clean it out?
the only way is to run a empty load of warm water w/heavy bleach after running cycle wipe door boot/gasket out with like kitchen cleaner w/bleach making sure you get in between the tub and the front panel on the boot. then you have to ALWAYS leave the door open to dry. TRY THIS AND LET ME KNOW
Bill
Jan 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Oven cleaning bosch oven
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Feb 10, 2008 | Ovens
Hotpoint self-cleaning oven
  I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
Washing Machines Logo
1,537 people viewed this question
Top Washing Machines Experts
