How do I use rigid vac to drank water out of my washing machine?
  • 111 Answers
If this is a top load that should be simple. Just put the hose in the wash pan and turn on the vacuum. If it is one of those HE front load washers, there should be a drain outlet / drain filter somewhere on the chassis. You may have to take the panel off.
Also this link gives you another example:
How can drain the water of my Front Loader washer in case of an emergency
Posted on May 01, 2017
Why is water leaking during fill?
a damage on the lead might be a threat that causes water leakage
Feb 16, 2016 | Washing Machines
How do I get the Rigid Wed Dry Canister vac to start?
Check the plug......I have a Rigid and have replaced the plug.
Aug 21, 2014 | Rigid WD1278 Canister Wet/Dry Vacuum
Won't finish the wash cycle
Initially we 1)used less detergent and make sure its marked 'he' . extra soap suds initiates error codes. 2) ran white vinegar with no detergent to clear suds 3) opened, checked and cleared trap.
Everything worked for a time but codes would return or like you would not finish wash cycle until water line in back of machine was made rigid so there was no chance of water or sud backup. So far so good. Good luck.
May 27, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Haier washer gwt450aw will no drain the water from the rinse cycle or spin. What could this be?
Get a wet dry vac and remove the filter in the vac so you can suck all the water out of the tub of the washing machine then slide the washer out so you can remove the drain hose and vacuum it out.
Dec 11, 2012 | Washing Machines
My washing machine isnt taking the conditioner instead the compartment is filling with water.
Some techs will usually say to clear your hose out with a coat hanger, but with your model, hot water and a wet/dry shop vac will do the trick. Make sure the water is very hot, but not so hot it melts the plastic. Fill the cup with the water and when it has drained about halfway down apply the shop vac to the drain hole itself and your dried softener will come back up the tube into the vac, clearing your softener tube. This happens when you do a few cold or warm washes and the softener clings to the tube and dries there.
Mar 18, 2010 | Candy AQ130 Front Load Washer
Gentle Annie wont pump out water
could have a sock in pump vac and towel needed unplug empty water remove drain hose shop vac pump and both hoses turn on to see if pump motor runs
Feb 04, 2010 | Frigidaire Washing Machines
How do I drain the outer tub of my washing machine?
If you own a wet/dry shop vac this can take about 5 minutes. Pull the drain hose from the stand pipe at the wall and pull a vacuum using the shop vac. These front loaders usually only hold about 5 to 7 gallons when full.
If you do not own a shop vac, you will need to access the drain pump and either remove one of the drain lines, or remove the clean out trap cover on the drain pump (if equipped). You will need a lot of extra towels to catch all the water. This can be a messy method to use.
If you need further assistance, please post back with your brand name and model number. All front loaders are not designed the same and this makes it much easier to diagnose. I hope this helps you.
Jul 05, 2009 | GE WVSR1060A Top Load Washer
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
that isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
Sep 29, 2017 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
