Question about Brother Sewing Machines
Hi! I have a Brother LS-400 sewing machine and need to know how to clear the display above the stitch selector panel. It says "bobbin winding" and I am trying to see, not wind a bobbin. Thanks
SOURCE: Bobbin winding won't clear off screen
Am taking it to the shop.
Posted on Jul 08, 2008
SOURCE: I have a Brother model
just wind the thread around the bobbin, don't put it through any holes, wind it around the center pole,
Posted on Aug 10, 2008
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
SOURCE: Can't wind the bobbin
Hi again,
Well we finally downloaded a service manual that cost a few bucks, then finished getting the machine apart, then found a small rubber O-ring that had obviously gotten hot when spinning after the tangling of the thread on the bobbin stem. You could see where the heat had melted tiny teeth marks in the ring and it was stretched out of shape. It and yours too will need to be replaced.
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
Digital display shows bobbin wind. Bobbin wind spindle moves slightly. When depress foot pedal, stitches for only a minute- stops. Cannot select any stitches as menu display remains on bobbin wind.
try putting a bobbin on to wind and then take off again, make sure when you do that the bobbin holder clicks back into the sewing position not the winding, you might need to give it a little push in the right direction then see if it sews ok for you. if not may need a service call.
Jul 20, 2017 | Sewing Machines
Adjust thread tension
Looking at a pic of this model, there are two dials on it. One near the top, one much closer to the needle. I believe the tension dial is the one that's close to the needle.
I don't quite understand what the problem is with the stitches from your description, but first try the tension dial. Reset it to zero and then try each setting, one by one, to see what happens.
If stitches are still wrong, a few things always to try when there are stitch problems. Clean well around the bobbin case, remove all lint. Do this often anyway, it's not good to let lint build up.
Try a new needle and a new spool of thread. Rethread the machine, a few times if need be. Try a new bobbin too, or wind a new bobbin to try from a new spool.
Try to get a manual for this machine. If Brother no longer has manuals, there are many sites that sell manuals for many machines. A manual can be your best friend when there are problems.
Jul 06, 2014 | Brother LS-2125 Mechanical Sewing Machine
How to troubleshoot without a manual
Yes, Brother has a free download, Go to this site: and you should have what you need. You also might have the bobbin pushed to the right, in the wind position. Is so, push bobbin to the left and all should be fine.
May 03, 2014 | Brother CS-6000i CS6000i 60-Stitch...
How to wind a bobbin on a brother LS-1520
Hi. You can get a manual for your machine from (scroll down to Manuals and Documentation). The manual will have all this information for you.
Happy Sewing!
Mar 05, 2010 | Brother LS-1520 Mechanical Sewing Machine
Self winding bobbin
I think you need to push the bobbin winder (with your bobbin on it) towards the handwheel. Press the foot pedal and it should begin winding. If this doesn't solve your problem, post back with more details of what you've done and the kind of problem you are having.
As a last resort, go to Sears and let them show you how to wind a bobbin.
Feb 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
