Question about Kenmore Dishwashers
Kenmore dishwasher. Flashing green light indicating "Clean" is permanently on. So, cannot initiate a wash cycle!!
    Top Expert:
  • Kenmore Master
  • 80,407 Answers
More than likely the dishwasher control panel has failed.
Posted on May 01, 2017
Green light flashes on clean. Will not run wash cycles. Will drain, Is there a reset button somewhere?
To reset your dishwasher, press the buttons [heated dry] [normal] [heated dry] [normal] to initiate the diagnostic cycle. This should clear the error message from the system and allow it to run again. If the problem persists, check the causes found here : http://bit.ly/gitWix
Mar 05, 2011 | Kenmore 24 in. 17039 Built-in Dishwasher
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 05, 2011 | Kenmore Dishwashers
My dishwasher is stuck on clean mode? what can i do to reset? it finished cleaning, then will not cancel. just green flashing light that says clean. i tried to unplug the washer for about 1hr ,but no help.
The flashing clean light is an indication of an error during the cycle. I put together an explanation of this and how to reset the control so you can use the dishwasher again. Follow this link and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 04, 2010 | Kenmore Dishwashers
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
