Question about Garden
I have gas in my oil, do I have to replace the carburetor, or can it be repaired? this is on a coleman 6250 generator
    Top Expert:
  • Garden Master
  • 42,122 Answers
It can be overhauled
most likely a faulty needle and seat problem allowing the fuel to leak past and out into the manifold into the sump
Posted on May 01, 2017
    Top Expert:
  • Garden Master
  • 75,822 Answers
Drain the oil and rebuild the carburetor.
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Generator 6250 coleman spark plug will no fire
First check your oil level. The low oil sensor kills the ignition to protect the engine from damage.
Second, replace the spark plug.
Sep 17, 2014 | Briggs & Stratton Electrical Supplies
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
I have a 6250 coleman powermate and have not started up in a few years. I was able to get it started with the choke and let it run for a few minutes. I keep on trying to switch it to run and it just will...
Your carburetor jet is likely plugged with varnish / wax from the old fuel that was allowed to sit in the carb. You will have to remove the carb, and clean it at very least. Since you already have to disassemble it, you may as well rebuild it.
Jan 04, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
Jul 30, 2009 | Electrical Supplies
Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
Checking the gas and oil levels?
There isn't really a guage to look at . What one does is to take out the plastic plug on the side of the engine and with the engine cold and level make sure that the oil level comes up to the lowest thread where the plug screws in.
You really should have a manual, so if it's missing look here for which ever "PM" number is printed on the tag on the end of your generator.
Regards,
Carl
Jan 06, 2009 | Coleman Electrical Supplies
Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Sep 10, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
