Question about Kenmore Vacuums
Need to find electric brush roll for Kenmore intuition 31810
    Top Expert:
  • Kenmore Master
  • 79,865 Answers
Please contact www.Searspartsdirect.com. This website doesn't sell parts.
Posted on May 01, 2017
How do I replace a carpet pro brushroll
How may vary depending on your specific model but you need to make sure it's unplugged from the electrical outlet, lay it flat on the floor so the bottom plate and brush roll are facing up. Remove the bottom plate screws and the bottom plate. Pull the brush roll out and clean out hair, dust and lint. Put new belt around motor shaft and put brush roll through the belt and pull on brush roll to stretch belt far enough to put back in vacuum. Install bottom plate and spin brudpsh roll by hand to insure it isn't restricted before you turn it back on.
Jan 05, 2017 | Carpet Pro Vacuums
The end cap of intuitive agitator must be replaced
The bearing or bushing probably had hair or debris restricting it which caused it to get hot and melt the end cap. You will most. Likely need to replace the brush roll, also replace the belt.
Jan 26, 2015 | Vacuums
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Kenmore help
There are 2 plastic screws that pivot 90 degrees on the top of the front nozzle. Turn them and lift off the hood. You will see the brush roll and belt. Remove the brush roll and clean off any debris or hair, also from metal caps at the ends of the roller. Be careful not to loose the 2 washers under the end caps. Place the new belt on the motor shaft that sticks out of the main body, then place the brush roll pulley against the belt and pull forward and lock the roller in position. Spin the roller by hand to make sure that the belt is aligned properly. Place the hood back on the front nozzle and turn the plastic screws to tighten. Have fun cleaning.
Nov 05, 2013 | Vacuums
Kenmore Intuition wand very hard to pull out of head.
No vaseline. You can use wd40 or silicone spray.Also check to see if the wand is bent out of round where it meets the handle
Sep 06, 2009 | Vacuums
Brushroll in electrolux oxygen+ deluxe
Is the brush roll not working at all? Check the teeth at the sides of the brush roll by opening up the electric head. If it has completely been destroyed you may have to buy another new head for it. Separate brush rolls are difficult to obtain and work out more expensive sometimes than the electric heads themselves.
You may have to contact the Electrolux cust services in your own country. Check by Electrolux.com
Jul 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Rotating brush
Sounds like the brush roll has an end that is melted or frozen up so it won't move, in which case you need to replace it.
May 08, 2008 | Vacuums
How to take the brush out?
There should be screws on the bottom plate covering the brush roll, take those out and it should come off and then you can access the brush roll.
Feb 17, 2008 | Kenmore Progressive Bagless Upright with...
Vacuum is making a loud noise
Is the smell rubber or electrical. If rubber then the belt is slipping and needs to be replaced, they stretch after awhile. Also is the brush roll turning freely, or is it bound up, it may have to be replaced. If the smell is electrical, then probably the motor is going bad and will have to be replaced.
Dec 03, 2007 | Kenmore 35622 Upright Vacuum
Owners manual
remove bottom plate, remove brush roll. slip new belt over motor shaft then onto brush roll. refit brush roll and bottom plate. its just meccano
Mar 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
27 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
