Question about Garden
Do I turn the nut to loosen the blade on a sears gas edger to the right or left?
  • 155 Answers
Most times it is the opposite way to which it turns.
Posted on Jul 25, 2009
How do I loosen the blade nut on my Ryobi 4 cycle edger? Which way does it turn??
Try heating the nut slightly with a gas torch and continue to turn counter clockwise as the manual suggests to undo.
The heat will expand the nut slightly making it easier to undo, don't overheat the nut as this could damage it.
check their isn't any locking washers holding the nut in place, bend the washer out of the locking position if this is the case.
Try using a larger spanner or extend your handle to give you maximum leverag
Jun 28, 2014 | Ryobi RY13050 4 Cycle Wheeled Edger Lawn...
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
To remove the circular saw, which way do you turn the nut hold the blade on the saw?
For any saw blade or grinding wheel, the rule is this. Pushing against the points of the teeth should be the direction that tightens the nut. So you must loosen it in the same direction that the blade spins. For example, if your saw blade is on the right side of your saw, then the blade spins counterclockwise, and the wood pushes against blade clockwise - so you turn it counterclockwise to loosen it (which is in the same direction that the blade spins.). If the blade is on the left side of the saw, you loosen it clockwise. Good luck, Al K
May 22, 2011 | Sears Craftsman Circular Saw Blade
Unable to get nut off of a craftsman convertible edger.
Lock on the blade with a pair of ViseGrip Pliers, then try turning the nut, they are installed quite tight, also try clockwise, maybe left hand nut.
May 25, 2010 | Craftsman Convertible 25cc. Gas Line...
Is the nut for blade removal right hand?
on blade removal it is opposite. Lefty tighty, righty loosen
Mar 29, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Trying to remove Blade from gas edger ---- very tight. To loosen, do I force left or right turn?
All the trimmers/gras cutters have blades rotating clockwise. So, to loosen, you have to turn the bolt left. If too thight - use WD-40 Spray. It puts some grease :)
Aug 04, 2009 | Garden
Can't remove the nut holding blade on. Which way do I remove
Get some WD-40 and spray the area around the nut then let it sit for a few hours. This will get into the threads and loosen any rust that is compounding your problem. Now get a good wrench and look directly at the nut. Left is loose and Right is tight.
May 21, 2009 | Craftsman Gas Mini - Tiller/Edger
How to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Apr 09, 2009 | Garden
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
