Dell Inspiron 5150. Will not turn on. While plugged in and pushing the power button the battery light turns orange flickers a few times and then nothing.
  • JackDD Jul 25, 2009
    I should have added that the a/c power cord is power, (power light is on) and I actually tested the plug, it is registering 16.5 volts, what it actually supposed to be putting out. thanks for the suggestion.
  • 103 Answers
Its not getting power from your power cord, if you have a friend that has a power cord, try theirs. If there's a light on your power cord it should be lit up but still doesn't determine if you cord is bad.
Posted on Jul 25, 2009
  • Nathan Wells
    Nathan Wells Jul 25, 2009
    that sounds about right, if thats not working your power supply has gone bad in the computer or the little prong the power hooks into could've snapped
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Battery icon flickering when plugged in
this is common within your product series. i actually havent seen one that doesnt do that. it either means the battery is dead or the motherboard is bad. and im starting to lean tword motherboard only because this is such a comon problem. and even after people buy new batteries, it still does it. so i believe its your motherboard.
May 10, 2009 | Dell Inspiron 6000 Notebook
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Will not turn on......
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
Dell 5160 orange light
removed battery, and acadapter FROM UNIT, HOLD DOWN THE POWER BUTTON 60 SECOND That should drain the power from it
Mar 26, 2008 | Dell Inspiron 5160 Notebook
My Dell Inspiron 1150 PC Notebook Won't Turn On
Norm.. Suffice to say these are a problem. Is it a P35 Adapter? If so look for a replacement and retry. If this does not help Check the CMOS battery voltage as crazy as it may seem but the Dell adapters are a little more complicated than a standard 2 wire output adapter. They have a 19V Feeder or main supply, The Negative or Ground as some people/techs call it as well as a 3.3V data circuit thats related to the Embedded controller chipset, BIOS and other circuits on the board. Also see if you can find a friend local with a known good working battery/adapter if you cannot afford or dont want to spend money on it. If all else fails yell back weve repaired a ton of these and they should have been included in the 5150/5160 Dell Class settlement in my opinion as they have a ton of similar components/issues..
Good Luck! Ken
www.ikenfixit.com
Jan 15, 2008 | Dell Inspiron 1150 Notebook
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
