BROKEN SPINNING LENS CRACKED NOW MAKES A VIBRATING SOUND AND DONT FOCUS
  • 2,237 Answers
It's a colorwheel and you need to replace it.
Posted on Nov 10, 2009
  • only1pj Oct 29, 2010
    @alexandercre did you source the broken part? I have had the same problem for a long time, the projector got shelved and left to collect dust.
    @projdoc can you recommend a site / store which sells these for a benq mp612.
    Regards,
    Peter
T3. Why does it sometimes not focus and take the shot unless the lens is fully zoomed in or out?
You may have a cracked or broken contact ribbon connector in the lens. Does it work OK in manual focus? if it does then the ribbon may be the problem. It'll need a repair job.
Feb 20, 2016 | Canon Cameras
The kit lens has stopped auto focussing all together, just makes a noise every now and then.
Two possible reasons ... A: the ribbon cable which runs from the rear mount contacts to the mid barrel has either cracked or broken (this eventually happens with continued zooming at some point in its lifetime) B: the focussing gear cog has small particle such as sand or broken plastic debris which prevents auto from fixing to focus point.
Solution is to try using a blower from rear at full extension to see if it is debris ...or inspect ribbon cable.these are readily available on eBay as replacement spares.
Jun 06, 2015 | Canon EOS 450D Digital Camera with 18-55...
Canon Rebel XSi won't autofocus and makes grinding sound
There is nothing that auto-focuses except the circuit in the body - all the motors, gears etc. are in the lenses. If this is a 18-55 lens then more than likely the long shaft gear has broken teeth - a very common problem.
Mar 30, 2013 | Canon Rebel Cameras
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
It is making a constant strange noise when it is turned on. does it mean it is broken?
Not necessarily.
This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off:
1: Go into the menu
2: Chose option Cam Settings
3: Switch AUTO focus to single lens and click OK.
Jan 26, 2010 | Kodak EASYSHARE M763 Digital Camera
Lens doesn't go in or out - just whiring sound and focus error message
these are really small parts & tend to pop out of place with little impact, you can take the lens apart & pop the out of place piece back in if it's not broken
Nov 30, 2009 | Fuji Cameras
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
This is exactly my problem.
Focus is stuck - could be sand or something in the focus gears. That's the weak spot for these lens. Contact your local Olympus service center or any other camera service center or me at toms.safranovs@gmail.com
Tom
Jul 28, 2009 | Olympus FE-170 Digital Camera
Sony cyber-shot dsc-w50
Sounds like you have two problems, both which mean bad news. The clicking could be a broken gear in the lens unit or off track lens.
The colors may be caused from a bad ccd or sensor internally.
Aug 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
148 people viewed this question
jasbo
jasbo
