Question about Singer Sewing Machines
How to adjust bobbin tension on a Singer 111w 101?
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
Posted on Oct 26, 2008
  • 69 Answers
SOURCE: How do you adjust the bobbin tension on a Singer
With your slide plate open, you will see 2 screws on the bobbin case. You need to adjust the one on the inside (not the one that sits at the edge of the metal strip). Do so very slightly. If you can't seem to get it adjusted, take a look and make sure there isn't any thread or lint in between the two pieces of metal that the thread feeds through. This can cause a loose tension.
Posted on Mar 01, 2009
SOURCE: Loading the bobbin and adjusting the tension.
Loading the bobbin for this maching is fairly simple. First thread the machine. Then after placing the bobbin in the machine pull the thread out through the first notch and back through the second. (The end of the thread should be going in the direction of the little channel on the left side of the bobbin area.) Now what I did was make a loop with the end of the thread and pushed it under the casing below the needle. Then if your machine is threaded correctly you should be able to turn the knob on the right side of the machine so the needle goes down and comes back up once. If you've done it right the bobbin thread should come up in the correct spot.
Posted on Mar 15, 2009
  • 87 Answers
SOURCE: Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 19, 2009
  • 139 Answers
SOURCE: Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
How to adjust the bobbin tension adjustments on a 1036 Singer
You can search the internet for web sites and videos that discuss and demonstrate adjusting bobbin tension.
Nov 16, 2016 | Singer Sewing Machines
Bobbin tension
adjust the top thread tension and see if that helps the bobbin tension
here is a link for a free manual for the machine
Feb 27, 2013 | SINGER 7470 Sewing Machine
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Feb 23, 2012 | Singer 5050 Mechanical Sewing Machine
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Singer 15 thread breaks and doesn't sew
if the upper needle thread is breaking adjust the thread tensioner if the bobbin thread is breaking adjust the bobbin tension screw on the bobbin case
Feb 16, 2009 | Singer 3343 Mechanical Sewing Machine
Bobbin tension is too loose
Dec 08, 2008 | Singer 7422
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
