Question about Coffee Makers & Espresso Machines
Saeco Odea Go espresso maker. Quick flashing red light (exclamation point) will not stop and water will not come out.
3 Suggested Answers
  • 8 Answers
SOURCE: saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Posted on Jun 24, 2009
  • 910 Answers
SOURCE: Saeco espresso coffee maker -
Priming is detailed on Page 7 from Step 7 of the Manual at the link belw.
http://www.gtp.com.au/espressotemp/inewsfiles/Saeco-Odea-Go-user-manual-english-watermarked.pdf
Posted on Aug 19, 2011
My saeco odea giro coffee machine has a red light flashing quickly. The light looks like an exclamation mark. No matter what we have done to try and correct it still doesn't stop.
First try to prime the machine.
Turn on hot water and prime about 100 ml hot water. If the red light remain you have to change the flowmeter.
Nov 01, 2017 | Saeco Coffee Makers & Espresso Machines
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
Exclamation point flashing
For Saeco Odea Go Team De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler.
3. Remove the brew unit from the machine. Check the mechanism and refit the same into the machine.
You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Nov 03, 2014 | Saeco Odea Go
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Mar 26, 2013 | Saeco Odea Giro Plus Coffee Maker
Saeco Giro II Red Light stays on, even after removing watertank, dredge drawer and brewing unit, and replacing. Red light does not flash after removing dredge and brew unit.
Had the same problem, if you used steam or hot water, make certain the steam knob on top is all the way back in the close position, if not the red exclamation sign will stay lit.
Dec 12, 2010 | Saeco Odea Giro Espresso Maker -...
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Saeco odeo giro and the red squiggly light
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
