I lost the 4-digit pass code to my DTVPal by DISH. Is there any way I can reset the code or even reset the whole unit?
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
You should make it a system reset. There are two methods to reset.. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the device from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand devices are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on May 02, 2017
Not receiving signal
Do you have all connections hand tight? Are you getting an error message on the screen? What type of cable are you using to connect to the TV, Coax or RCA?
If you're not getting an error message what type of cable are you using? If it's a Coax Cable, you will want to make sure the TV is on channel 3 or 4. If you're using an RCA Cable, you will need to check the Input channel.
Thanks
Apr 04, 2014 | DISH Network DTVPal DVR by
Lost my 4 digit pass code how do I fix
What is Mobile Phone brand and Model?
You can reset the Phone easily using the default code ,If the default code not work means use master reset code.Default codes for Nokia Phones is 12345 or 1234 or 0000 or 00000..If these code not works get the master reset code for DCT Nokia phones and Alcatel Phone Old models at Unlocking4free.com and reset it.
Jul 28, 2012 | Cell Phones
Change combination, lost book
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
Here is a link to the complete instructions:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Jul 25, 2011 | Weiser Lock Powerbolt 1000 Lock
Hello
Hello! Are you having a problem with your DTVPal Dvr???
Jan 19, 2011 | DISH Network DTVPal DVR by
I get new DTVPal DVR for 2 month. and it can not start. press start on remote. the green light just on less a second and off by it self. who can I get wanrantty, where can I have custom service phone...
Hi this is Mike Houston of DISH Network. I will be more than happy to help you with that phone number 1-800-333-3474. We also have troubleshooting as well on DISH Network and that link is
http://www.dishnetwork.com/supportsection/troubleshoot
Jan 16, 2011 | DISH Network DTVPal DVR by
My dtv pal dvr is a few months old and is unusable. It freezes up sometimes for hours i cant even turn it off. The content comes off an antenna that gets a strong signal but it skips like it is getting bad...
Hello! Dan Busa with DISH Network customer service. This may be a signal reception problem you can try checking cabling and connections coming from your antennae.
Dec 30, 2010 | DISH Network DTVPal DVR by
What is the phone number for Dtv???
I would be happy to provide you with an Email for any concerns that you have with your DVTPal. Feel free to contact us via Tech@echostar.com. If you would like additional information on your DTVPal in general please visit: http://www.dishnetwork.com/dtvpal/support.shtml.
Phillip Chang
DISH Network Customer Service Representative
Nov 14, 2010 | DISH Network DTVPal DVR by
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Will my Maganavox 20MS233S handle digital?
With an external converter, yes. I'm using a DTVPal from Dish Network.
Sep 22, 2008 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
Top Televison & Video Experts
