Can not print documents on my or sent out by fax MFC845CW
checkitright
  • 1362 Answers
SOURCE: Print fax journal from previous date on Brother MFC-3820CN
although it may have a time retreival function it will not store 2mo of faxes !! most likely only a few days depending on the amount of fax you receive
Posted on Dec 10, 2007
  • 35 Answers
SOURCE: Printing a sent fax
in the settings of the fax there is a setting in reports that you have to turn on conformation with print out.
that gives you time date and 1/2 of the top page of fax sent
Posted on Jun 13, 2008
SOURCE: occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
Posted on Nov 24, 2008
  • 23 Answers
SOURCE: I need to get a copy of a document that I faxed.
This might be what you are wanting. Hope it helps.
Including the first page of each fax on the fax call report
If this option is turned on, the fax call report will display a thumbnail (50% reduction) of the first
page of the last fax that was sent or received.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
1 Press menu/enter.
2 Use the < or > button to select Reports and press menu/enter.
3 Use the < or > button to select Fax Call Report and press menu/enter.
4 Use the < or > button to select Include First Page and press menu/enter.
5 Use the < or > button to select On or Off and press menu/enter to confirm your selection.
Posted on Feb 13, 2009
  • 169 Answers
SOURCE: when I attempt to print on 6310, it goes to fax mode
go to control panel >printers andfaxes and see which printer is set as he default printer....it is the fax rgt now.....rgt click on the pirnter icon and change it to the default printer.....should work....
Posted on Jun 25, 2009
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
I would like to print a transmission report for a document that I just sent.
Hi
You can print a log of faxes that have been received and sent by the device. Each
entry in the log contains the following information:
• Transmission date and time
• Type (whether received or sent)
• Fax number
• Duration
• Number of pages
• Result (status) of transmission
To print the fax log from the device control panel please follow the directions below
1. Press Setup.
2. Press right arrow to select Print Report, and then press OK.
3. Press right arrow to select Fax Log, and then press OK.
4. Press OK again to print the log
All the best!!
Regards
Nov 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Confirmation page needed
Press MENU - 2 4 1 then you can choose to have that feature ON or OFF. the +Image means that it will also print a copy of the first page sent so you can actually verify the document sent.
Mar 31, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Printing out a confirmation page for a document automatically
press FUNCTION, 7, 4, SET, 1, 2, SET, 2, SET, STOP...It will print everytime you fax out a document.
Oct 02, 2009 | Panasonic PanaFax UF-8000 Laser Fax
HOW CAN i PRINT MESSAGE FROM MEMORY FROM AN e-STUDIO 50f
Are there error messages on the display or do you want to print something that has been sent? If your fax machine needs toner/drum unit, then that will need to be replaced first. If you are looking for a document that was faxed to someone, you will need to call them and have same document faxed back to you....fax machines have memory for incoming faxes, but not for things that are "sent".
Jul 17, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Are you able to print out a fax that was sent out approximately 6 months ago
No. Not from a fax machine. Some faxes have the ability to store sent faxes but this feature caused more problems with memory filling up than it solved. So, the machine usually deleted the job after a short period and it is extremely unlikely that your sent document is anywhere near your fax now. Not a stupid question though.
Jul 09, 2009 | Lexmark Office Equipment & Supplies
How do u print confirmation from a previous fax?
All you can print out is the tranmission report. It will show the fax number the item was sent to and if it went though OK.
Apr 16, 2009 | Brother IntelliFAX 1840C Plain Paper...
Fax not received
No, just the fax phone number.
Mar 09, 2009 | Ricoh 3310Le Fax Machine, FAX3310Le...
Faxes being sent but stuck in memory, How do I Print them out?
Printing Documents in Memory: From B640 Manual
Except when you run out of paper, the faxphone will automatically print out the contents in memory when you remedy the cause of the problem.
If running out of memory caused memory reception, adding recording paper and press {STOP} to begin printing the stored page(s).
After printing the page(s) in memory the faxphone erases the documents from memory.
Jan 19, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Dec 06, 2007 | Office Equipment & Supplies
26 people viewed this question
k24674
jasbo
jasbo
