My control is a nb991, my question is if the model nb954 serves me to control my bluray
I have a remote that I want to control my bluray
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 26, 2014 | Televison & Video
My playstation 3 will not play disc i replaced cd?
your ps3 laser is definitely on the frits or completely fried. it tends to happen to ps3 more frequent in dusty or smokey homes or rooms. not much you can do it cost overe $100 to fix when you can buy brand new one for $100 more. the problem is fixable but my opinion a new one is a better option. you can still use the burnt laser ps3 to watch netflix or other forms of files not dvd or cd
Jun 01, 2014 | Sony Playstation 3 (PS3) Console
SONY REMOTE TO A ELEMENT TV CODES
Element TV ELEFT422 can be controlled by Sony BluRay Player remote model # RMT-B118A by entering the code 04 (same as Goldstar and LG TVs)
Sep 22, 2011 | RCA RCR311B Remote Control
Sylvania Bluray NB501SL9 audio stopped on bluray discs but not regular dvds
threre are actually three lasers in a bluray drive. the bluray one has died. this also happens in ps3's. laser replacement for that model should do it
Nov 24, 2010 | Sylvania NB501SL9 Blu-Ray Player
Need new update to play avatar.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
May 10, 2010 | Sharp AQUOS Blu-ray Disc Player
My blu ray player won't play blu ray copy of avatar
Try completing the update.
model not listed
May 04, 2010 | Sharp AQUOS Blu-ray Disc Player
Ps3 not reading disc
You need to replace your bluray drive or send it to sony for repair
May 03, 2010 | Sony Playstation 3 (PS3) Console
I recently reset my ps3 and now my bluray controller wont work
you go to settings- and then search for something called bluray remote control initialising or something.
and from then you can intitialise it. hope this helps
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
Bdp s350 sony bluray player.
I would just like to add that I have a Sony BDP-S500 player and a Sony TV.
The Sony TV's remote was preprogrammed to control the Bluray player, which i discovered by accident, so I didn't have to mess with universal remote control codes or anything.
Hope that helps.
Jun 17, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
