Question about Garden
I have an older marksman repeater and I don't know how to put the trigger spring back
5 Suggested Answers
SOURCE: marksman 1010C repeater air pistol
sorry if you already learned but you have to **** it, and at the front under the barrel exit is a button looking shape press down on that really hard and on the top of the gun a sloped shape should appear. do not put the bb in the circle shape hole put the bbs in the top square shaped hole. push the object down and aim then pull the trigger!
Posted on Apr 07, 2009
SOURCE: Need a view of the inside of a Marksman bb pellet
I need a diagram of a marksman .177 cal
Posted on Dec 14, 2009
SOURCE: Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Posted on Jun 02, 2012
  • 3519 Answers
SOURCE: how do I put the throttle trigger back together?
Hi Myles:
Since I don't know your machine, I can only give you the logic that I would follow if I were given your box of parts.
- The springs are intended to return the trigger to the idle position.
- With the motor off, Move the trigger from idle to full on, then back to idle. That's what is upposed to happen with the spring pulling it back.
- The other spring is connected to a governor. that is sometimes a "vane" that gets air from the blades on the flywheel, but the idea is that when th engine is under load, more throttle gets applied.
Consider it a fun project in logic.
Play with it, and all of a sudden all of the bits will be right and you'll be cutting grass like a mad thing.
Cheerfuls.
Posted on Nov 27, 2015
How do I put the throttle trigger back together?
Hi Myles:
Cheerfuls.
Nov 26, 2015 | Garden
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Optics
Marksman 44-1c Cal 4.5 (.177) Spring loaded Pellet gun
All I can tell you is that Beeman is the maker, and Marksman is just a model.
Apr 12, 2014 | Optics
Parts schematic marksman repeater pistol
http://www.pyramydair.com/manual/marksman-1010
This is easy to disassemble but take careful notes/ pictures as you go because the springs have to be in the right places.
Oct 21, 2013 | Sport & Outdoor - Others
How to put in co2 cartrige in a.177 cal 4.5mm
Hi wendyavery...
The Marksman 2000K does not use CO2 cartridges, it uses a spring to act as the "power plant"
Go to the following webpage and check it out
Please rate me
Bud
http://www.pyramydair.com/s/m/Marksman_2000K_Air_Pistol/644
Oct 06, 2012 | Marksman 2000K Air Pistol - 0.177 Caliber...
I need a diagram for the trigger. I cant figure out how to put the spring back into the trigger. It popped out on me while I was workin on it and didnt notice how it was put in?
Look closely inside the handle where it lays. There may be a small plastic post there to hold it and/or the spring. Realize when the trigger is depressed (up against the handle) the spring is loaded and it pushes the trigger back down if you let go of it. Lay the spring in the general area and look for any scraping of the plastic which may show you exactly where it went.
Aug 13, 2010 | Craftsman Garden
Marksman 1010C repeater air pistol
Sep 08, 2008 | Sport & Outdoor - Others
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
