Question about The Toys
How do you reset the tach on a Massey Ferguson 1125? I replaced the cable now engine runs faster than tach. When off needle is way left of 0
SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
Posted on Apr 07, 2009
  • 86 Answers
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
Posted on May 12, 2009
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
Posted on Nov 21, 2009
  • 165 Answers
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Posted on Feb 27, 2010
captjack163
  • 13 Answers
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Posted on May 01, 2010
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
What is the main bearing bolts torque.the connecting bearing bolts torque and cylinder head bolts totque for E3CD engine in 1540 massey ferguson tractor
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
Dec 05, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
Looking for engine no. for massey ferguson 290 seriel no. 392949
Go to ebay and type 'massey ferguson 290 engine' in the search bar
Sep 19, 2013 | Computers & Internet
Need a service manual Massey-Ferguson 135
This store seems to have tons of Massey manuals and some for the 135 tractor: Massey Ferguson Manuals
Jul 02, 2013 | A&I Products A-509057M91,Massey...
1950 massey ferguson timing gear alignment
what are the timing marks for a massey ferguson tef 20 1955 to put the timing back on
Apr 16, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
May 07, 2009 | Garden
Need a wiring diagram for a massey ferguson 135 tractor
I need a wiring diagram for my massey ferguson 135 tractor regards ****
Mar 24, 2009 | RTO Massey-Ferguson Tractor TE20, TO20,...
Toys Logo
Top The Toys Experts
Jennifer Rock
Jennifer Rock
David Payne
David Payne
Are you a The Toy Expert? Answer questions, earn points and help others
