Question about Miele Dishwashers
I have a Miele Inspira Series type HG03 dishwasher. The Intake/Drain light comes on and the dishwasher stops running on a weekly basis. We clean the filter regularly. Is this a sensor problem?
SOURCE: Mieli water-intake light comming on?
THIS IS THE INTAKE DRAIN LIGHT, THIS USUALLY MEANS YOU HAVE A DRAIN ISSUE, COULD BE A BLOCKAGE AT THE PUMP OR YOUR INSTALLATION IS INCORRECT, YOU CAN CALL MIELE CUSTOMER SERVICE AND ORDER A USE AND CARE MANUAL AS WELL AS AN INSTALLATION GUIDE, THEY ARE ALSO VERY GOOD AT TROUBLSHOOTING OVER THE PHONE @ 1-800-843-7231
Posted on Mar 12, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
SOURCE: Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
Posted on Jun 08, 2010
  • 12 Answers
SOURCE: Miele Dishwasher Intake/Drain Red Flashing Light
Does it fault out in the beginning, middle or end?
Posted on Nov 17, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele Inspira Series Model G2140 U All program cycle indicators are on. I unplugged the dishwasher for 60 secs. and tried a hot/pans cycle and all the lights returned. What can I do? Thanks, Leo
in this case you just have to know when you can doit or let the professional handle it. but before they come call the company and tell them that your machine has to be reset and to tell you what to press and hold to reset maybe that might work,sometimes you get a acknowledgeable person who knows a litte something something. it could save you some money on the repair.let meknow if i was of some help with a 4 thumbs up post
Feb 27, 2010 | Miele Inspira G2140 Dishwasher
I have an Miele Optima Series HG03 dishwasher. The dishwasher stops after a minute and the intkae/drain error flashes. I tried everything in the manaual but there is nothing blocking the drain or intake...
hi,
try checking the spigot under the sink as quite often the hole has not been opened up enough and there is a shoulder for food to jam up against causing a blockage. Remove the drain hose and have a look in the hole of the u bend.
If ok remove the filter in the base of the unit and remove the non return valve and make sure the drain pump can turn and there is not anything blocking it.
Dec 28, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele Dishwasher G2170 scvi type hg03 dishwasher problem
Remove and check the "non-return valve" and make sure it's clean. It snaps out and in easily. See page 47 of the manual for this dishwasher.
May 20, 2008 | Miele Advanta G2170SCSF Dishwasher
Dishwashers Logo
44 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
