Question about Kodak Office Equipment & Supplies
No projection My kodak 4400 slide projector does not project. Projector turns on and lamp lights up but no projection out the lens onto the screen. Whats the fix?
bobint17
  • 270 Answers
SOURCE: can't project SONY VAIO laptop onto screen with NEC projector
Change the chord with a chord with a new one preffered by that laptop.
Posted on Sep 11, 2009
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
  • 43 Answers
SOURCE: Sanyo PLC-SW30
Solved many many problems with this projector. Used the repair service manual.
You can get it free here.
http://yama.co.za/forum/index.php?topic=146.0
Posted on Dec 03, 2009
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
  • 412 Answers
SOURCE: Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Posted on Dec 30, 2010
Can a projector bulb grown dim over time, or is the problem ilsewhere?
yes, think of the light bulbs in your house, they burn out, so can projector bulbs, they do dim before they fail in most cases.
Oct 03, 2012 | Kodak Vintage Mod 4400 Carousel Slide...
Can a projector grow dim, or is there another problem?
If the projected image is getting dim,check the following:
1. 120 volts at the wall outlet.
2. Check that the lamp is completely seated in the lamp house / socket.
3. Cloudy appearance of the inside of the lamp. This indicates there is a air leak in the glass casing around the lamp filament.
4. The lamp socket contacts have a build-up of material on them caused by arcing between the socket contacts and the lamp pins
NOTE: Any of these items will also drastically reduce lamp life!
Good Luck!!
Jim
Oct 02, 2012 | Kodak Carousel 4400 Slide Projector
It hasnot been used in 12 years. it was working for afew days then it wasnt. the power was on but the big light in the back is out.is it the bulb or something else? Is it worth fixing? can I get an...
Chances are that if the cooling fan is running, then you burned out the lamp. Contact Bulbman.com or Bulbs.com for a quote on the lamp. If your projector is a Carousel 4400, then you will need to replace the lamp with an ANSI Code "FHS" lamp. If that's all that is wrong with the projector the lamp will cost you about $40 (best guess).
Dec 08, 2010 | Kodak Carousel 4400 Slide Projector
When I turn on the lamp with no tray mounted, the light shines through and shows a shadow of the slide lift arm on the screen. The tray does not properly mount on the projector and the For and Rev...
You are describing, among other things, a timing problem with the projector. That is why the light projects with no slide in the gate and the tray does not properly mount. This could have been caused by a slide jam, which "broke" the re-settable emergency clutch. To check (and re-set the emergency clutch), plug the projector in, turn it on and push & hold the reverse cycle button on the projector for a couple of cycles. If it fixes your problem - great!! Otherwise you need to contact an authorized repair dealer for repair.
Sep 10, 2010 | Kodak Carousel 4400 Slide Projector
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
The first slide advanced and then a black piece came across the lens and didn't retract. what do we do?
These projectors are equipped with a "dark shutter", which stays closed unless it detects a slide in the "gate" (projection path). With the projector on, try GENTLY inserting a pencil on the movable levers that hold the slide vertical in the gate. If the "dark shutter" does not open, then chances are the lever that "trips" it open has been bent or somehow moved out of position.
I recommend you contact a factory-trained repair dealer.
Nov 15, 2009 | Kodak Carousel 4400 Slide Projector
I'm testing my 4400. With slide tray loaded (no slides in tray) when I advance the carousel the light from the lamp does not shine through. Does the carousel have to have slides drop down in order for the...
Yes!! The projector is equipped with a "dark shutter", which means light is only allowed to exit the projector when a slide is in the gate. That eliminates the "white screen strain" on your eyes when no slide is present. Happy New Year!
Sep 16, 2009 | Kodak Carousel 4400 Slide Projector
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
Focusing into slide transfer box
Yes, use a shorter projection lens. You didn't say what focal length your projection lens is, but Kodak and many of their OEM vendors made very short focal length lenses.
Aug 02, 2008 | Kodak Carousel 4400 Slide Projector
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
