Question about Food Processors
I have an old food processor that says Signature Classics on the front. When I use it with liquid, the liquid comes out the sides on top. It's a mess. Am I missing a gasket or something? Ann
    Top Expert:
  • Food Processors Master
  • 40,418 Answers
The lid may be the wrong part or defective.
Posted on May 02, 2017
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Hello, I have lost my instructions for a cookworks signature food processor can you help please? Thanks Steve
Hi Steve,
Contact customer support via e-mail at:
or call during biz hrs at:
Jun 21, 2009 | Food Processors
I have a kitchenaid food processor and the bowl is tightly set on the right side of center. I can't straighten it out and when I try to move it, it sounds like I'm cracking plastic. It won't run! Any...
Items required:
-lemonade or other citric liquid
Step 1:
gently position poochy around tube in center of bowl. Fill halfway with lemonade or other citric liquid.
Step 2: Put lid of processor on and put entire unit in dishwasher. Turn on power scrub cycle.
The dishwashing cycle will help the citric acid to activate the poochy.
Step 3: Use skillz to wriggle the bowl off the processor. Empty out poochy remains.
Congratulations! YOU'VE GOT SKILLZ!
Jun 08, 2009 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Installing Cuisinart Sleeve/Sheath for DLC -7EMotor Shaft Cover
I have a DLC 7 pro circa 1982 - just replaced the sheath. First - remove old sheath - I found that using a plumbers pipe cutter to cut old sheath off in sections then pulling each section off with pliers works great. Make sure ALL the plastic comes off the metal shaft - as well as the brass ring portion of the sheath.
Next use a sharpie marker to mark the the "flat" side of the shealth = you must look inside the sheath, find the 2 "nubs" that form a "flat" side. These nubs must line up perfectly with the flat side of the shaft - mark the base of the shaft as well so you can more easily line up the flat of the sheath with the flat side of the shaft (and no, the flat outer sides of the the sheath do not match up with the flat inside section of the sheath - that would make life too easy!)
Press the new sheath on with your hand as far as it goes - should go down to about 1 inch from the base.
Now you need a hammer, piece of 2 x4 wood and brute strenght! (keep in mind that once you hammer it - even once - it will NOT come off) Put the 2" side of the wood against the top of the sheath - Use a LOT of force to hammer the sheath all the way down. will probably take 3 - 5 good strikes. It will take much more force than you think you should need to use. Make sure the base of shaft is as far down as possible - if it rubs against the workbowl while spinning it will fuse to the bowl! Good luck! -
Dec 02, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food Processor assembly
Hi Janne,
I bought a DCL 8M about 20 years ago and still have the original manual. Mashing potatoes is one of the few tasks that the manual discouraged. The potatoes turn into glue. I tried mashing potatoes with the flat blade and extra liquid. It still tasted awful. I do puree potato soup in batches, First I mash all the solids (potatoes and leek or potato and tomatoes), then add the liquid. For some reason, pureeing the soup works well.
I am sorry I could not be more helpful.
Oct 08, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
221 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
